  3. 急!平台突然很多服务起不来了,一直重启中
    yunmoo
    yunmoo
    我刚才删除了媒体库中之前设备上传的很多图片,但是资源好像没释放
  • hpH 离线
    hpH 离线
    hp
    这是在app下执行的,在airiot下执行下
    yunmoo
    在app下执行的
    yunmoo
  • hpH 离线
    hpH 离线
    hp
    您那备份文件很多吗,backup306g
    yunmoo
    找到了,有个项目备份很多,把这个备份删除就好了吗
  • hpH 离线
    hpH 离线
    hp
    磁盘满了得删除点不必要的文件数据释放点空间,才能解决问题,您先把没用的备份删除下
    yunmoo
    资源已经腾出来了,为什么还是不能启动?
  • hpH 离线
    hpH 离线
    hp
    服务器执行top看一下,另外看下core日志
    yunmoo
    0DEBUG msg=config loaded: ETCD.PASSWORD format:
    <DEBUG msg=config loaded: production_etcd__password format:
    3DEBUG msg=config loaded: MQ.MQTT.USERNAME format:
    /DEBUG msg=config loaded: MQ.MQTT.PORT format:
    <DEBUG msg=config loaded: production_mq__mqtt__host format:
    @DEBUG msg=config loaded: production_mq__mqtt__username format:
    'DEBUG msg=config loaded: HOME format:
    1INFO msg=watcher's ctx cancel : context canceled
    &DEBUG msg=config loaded: format:
    'DEBUG msg=config loaded: PATH format:
    +DEBUG msg=config loaded: HOSTNAME format:
    3DEBUG msg=config loaded: MQ.MQTT.PASSWORD format:
    /DEBUG msg=config loaded: MQ.MQTT.HOST format:
    @DEBUG msg=config loaded: production_mq__mqtt__password format:
    <DEBUG msg=config loaded: production_mq__mqtt__port format:
    ;2026/09/07 11:51:23 合并配置: {App:{Version: ServerID: ServerName:core RunMode:release EtcdConfig:/airiot/config/pro.json Platform:Multiple Etcd:{Endpoints:[etcd:2379] DialTimeout:10 Username:root Password:dell123 AutoSyncInterval:0s} PrintConfig:false Swagger:true Captcha:{Store:memory Length:4 Width:400 Height:160 RedisDB:10 RedisPrefix:captcha_} Log:{Level:4 Format:text Output:stdout OutputFile:log/service.log MaxAge:0 RotationTime:0 RotationSize:0 RotationCount:0 Syslog:{ServiceName: ProjectId:}} Gorm:{Debug:false LogLevel:3 DBType:postgres MaxLifetime:24 MaxIdleTime:0 MaxOpenConns:20 MaxIdleConns:1 TablePrefix: EnableAutoMigrate:true QueryMaxLength:0 CloseSingleQuote:false MySQL:{Host: Port:0 User: Password: DBName: Parameters:} DM:{Host: Port:0 User: Password: Parameters:} Postgres:{Host:postgres Port:5432 User:root Password:4P1jILKAq5 DBName:postgres SSLMode:disable Parameters: DBType: Distributed:false} Sqlite3:{Path:}} JWTAuth:{Enable:true SigningMethod:HS512 SigningKey:fNfkTmA0jQVp7WQ02T1c Expired:1209600 Store:file FilePath:data/jwt_auth.db RedisDB:10 RedisPrefix:auth_ StoreEnabled:false} Sessions:{StoreType: Key: MaxAge:0 RedisPrefix:} Redis:{Type: Addrs:[redis:6379] Username: Password:4P1jILKAq5 PoolSize:10 Timeout:0 DB:0} MethodOverride:false Server:{Metadata:map[env:local] HealthCheckCycle:0s HTTP:{Host: Port:9000 Timeout:0 CertFile: KeyFile: ShutdownTimeout:0 MaxContentLength:0 MaxLoggerLength:0 IdleTimeout:0s ReadTimeout:0s WriteTimeout:0s} GRPC:{Host: Port:9223 Timeout:0 Limit:0}} Endpoints:[] LocaleDir:/app/configs/locale Root:{UserName:admin} CORS:{Enable:false AllowOrigins:[] AllowMethods:[GET POST PUT DELETE PATCH] AllowHeaders:[Authorization Origin X-Requested-With Content-Type Accept] AllowCredentials:true MaxAge:7200} GZIP:{Enable:true ExcludedExtentions:[.png .gif .jpeg .jpg] ExcludedPaths:[]} Casbin:{Enable:false Debug:false Model: AutoLoad:false AutoLoadInternal:0} RateLimiter:{Enable:true Count:10000 RedisDB:1} API:{LiteMode:false Gateway: GatewayGrpc: EtcdConfig: Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:DCC1B0D6-868E-4C1A-B-3D-7E63-FEFB-D791 SK:21C6F030-B3AE-4E50-8-FF-9396-FD72-E15E Timeout:60 KeepAlive:false MaxIdleConns:0 IdleConnTimeout:0s Limit:0 Debug:false Service:{Expire:0s} ExpirePrecision:0} Flow:{Host:flow-engine Port:2333 WriteTimeout:60} FileServer:{FileServerType:localhost FileServer:/app/fileServer MediaLibraryPath:mediaLibrary SystemDefaultMediaLibrary:systemDefaultMediaLibrary OnlineDefaultMediaLibrary: SystemDefaultMediaLibraryMod:true UserFilesPath:userFiles MinioConfig:{UseIndividualBucket:false BucketName: SystemDefaultBucketName: Endpoint: AccessKeyID: SecretAccessKey: UseSSl:false ExpireIn:0}} MQ:{MQType:mqtt MQTT:{Schema: Host:mqtt Port:1883 Username:admin Password:4P1jILKAq5 KeepAlive:0 ConnectTimeout:0 ProtocolVersion:0 PubQos:0 Qos:0 Order:true ClientIdPrefix: ServerName:core EnableSubShare:false TLSConfig:<nil>} RabbitMQ:{Host: Port:0 Username: Password: VHost: Exchange: Queue:} Kafka:{Brokers:[] Version: GroupID:core GroupIDSuffix: ClientID:core MaxOpenRequests:0 Balancer: Partition:<nil> AutoCommit:<nil> AutoMark:false}} TSDB:{DBType:influx DBName:tsdb Timeout:5 MaxConn:50 MaxOpenConns:0 MaxLifetime:0 MaxIdleConns:0 MaxRetries:0 MaxDelay:0s Influx:{Protocol:HTTP Addr:http://influx:8086 HttpAddr: Username:admin Password:4P1jILKAq5 Sharding:true CreateDatabaseSql:create database "%s" RetentionPolicy: Precision:} Influx2:{Addr: Token: Org: Bucket: Username: Password: UseGZip:<nil> LogLevel:<nil> MaxRetries:<nil> MaxIdleConns:<nil> MaxIdleConnsPerHost:<nil> IdleConnTimeout:<nil> DialTimeout:<nil> TLSHandshakeTimeout:<nil>} TDengine:{DriverName: Addr: Field:{Time: ID:0 Department:0 Tag:0 Nchar:0 Varchar:0} WriteBatchSize:0 CreateDatabaseSql:} Cassandra:{Addrs:[] Username: Password: Consistency:}} Pprof:{Enable:true Prefix: Host: Port:9000} Trace:{Enable:false} Operation:{Address:http://operation:10088 Timeout:60} Lock:{Type:} Cache:{Expire:0s RedisExpire:0s HealthCheck:0s LockTTL:0s} TaskMode:} Forbidden:false FileServerType:local FileServer:/app/fileServer MediaLibraryPath:mediaLibrary SystemDefaultMediaLibrary:systemDefaultMediaLibrary SystemDefaultMediaLibraryMod:false UserFilesPath:userFiles Backup:/app/backup MaxFreeDiskSpaceForBackup:10 CryptoType: Html:/app/html LicenseDir:/app/license SVG:/app/svg Warningkind:[{"alert": true, "fix": true, "handle": true, "id": "ada21497-888f-4f6d-acc3-cb04250d8037", "name": "超限报警", "show": true }, { "alert": true, "fix": true, "handle": true, "id": "61024533-e716-439d-bf3f-e8f2a5c99128", "name": "仪表故障", "show": true }, { "alert": true, "fix": true, "handle": true, "id": "1f849be4-2907-4459-9665-3fda916bf286", "name": "其他报警", "show": true }, { "alert": true, "fix": true, "handle": true, "id": "1d345be4-2567-4764-7890-3ghj278vb342", "name": "数值超限", "show": true }, { "alert": true, "fix": true, "handle": true, "id": "1z875be4-2267-4564-7790-4kij278vb342", "name": "驱动掉线报警", "show": true }, { "alert": true, "fix": true, "handle": true, "id": "1z875xn8-2237-4544-7770-4kix918vb342", "name": "常规表数据报警", "show": true }, { "alert": true, "handle": true, "id": "1z875zt8-2357-4664-7756-4kfg9vzyu672", "name": "采集数据类型不一致", "show": true, "fix": true }] UseLicenseRefreshInterval:60 UseLicenseRefreshTimeout:1m0s}
    s2026/09/07 11:51:23 INFO 服务启动,运行模式:release,版本号:v4.4.163,进程号:1 tag=main
    �time=2026-09-07T11:51:23.339+08:00 level=ERROR msg="Redis客户端Ping错误: dial tcp: lookup redis on 127.0.0.11:53: no such host" tag=main logType=syslog service=core
    2DEBUG msg=config loaded: config.yaml format: yaml
    �2026/09/07 11:52:24 文件配置: {App:{Version: ServerID: ServerName:core RunMode: EtcdConfig:/airiot/config/pro.json Platform: Etcd:{Endpoints:[etcd:2379] DialTimeout:10 Username:root Password:dell123 AutoSyncInterval:0s} PrintConfig:false Swagger:false Captcha:{Store: Length:0 Width:0 Height:0 RedisDB:0 RedisPrefix:} Log:{Level:0 Format: Output: OutputFile: MaxAge:0 RotationTime:0 RotationSize:0 RotationCount:0 Syslog:{ServiceName: ProjectId:}} Gorm:{Debug:false LogLevel:0 DBType: MaxLifetime:0 MaxIdleTime:0 MaxOpenConns:0 MaxIdleConns:0 TablePrefix: EnableAutoMigrate:false QueryMaxLength:0 CloseSingleQuote:false MySQL:{Host: Port:0 User: Password: DBName: Parameters:} DM:{Host: Port:0 User: Password: Parameters:} Postgres:{Host: Port:0 User: Password: DBName: SSLMode: Parameters: DBType: Distributed:false} Sqlite3:{Path:}} JWTAuth:{Enable:false SigningMethod: SigningKey: Expired:0 Store: FilePath: RedisDB:0 RedisPrefix: StoreEnabled:false} Sessions:{StoreType: Key: MaxAge:0 RedisPrefix:} Redis:{Type: Addrs:[] Username: Password: PoolSize:0 Timeout:0 DB:0} MethodOverride:false Server:{Metadata:map[env:local] HealthCheckCycle:0s HTTP:{Host: Port:9000 Timeout:0 CertFile: KeyFile: ShutdownTimeout:0 MaxContentLength:0 MaxLoggerLength:0 IdleTimeout:0s ReadTimeout:0s WriteTimeout:0s} GRPC:{Host: Port:9223 Timeout:0 Limit:0}} Endpoints:[] LocaleDir: Root:{UserName:} CORS:{Enable:false AllowOrigins:[] AllowMethods:[] AllowHeaders:[] AllowCredentials:false MaxAge:0} GZIP:{Enable:false ExcludedExtentions:[] ExcludedPaths:[]} Casbin:{Enable:false Debug:false Model: AutoLoad:false AutoLoadInternal:0} RateLimiter:{Enable:false Count:0 RedisDB:0} API:{LiteMode:false Gateway: GatewayGrpc: EtcdConfig: Metadata:map[] Services:map[] Type: ProjectId: AK: SK: Timeout:0 KeepAlive:false MaxIdleConns:0 IdleConnTimeout:0s Limit:0 Debug:false Service:{Expire:0s} ExpirePrecision:0} Flow:{Host: Port:0 WriteTimeout:0} FileServer:{FileServerType: FileServer: MediaLibraryPath: SystemDefaultMediaLibrary: OnlineDefaultMediaLibrary: SystemDefaultMediaLibraryMod:false UserFilesPath: MinioConfig:{UseIndividualBucket:false BucketName: SystemDefaultBucketName: Endpoint: AccessKeyID: SecretAccessKey: UseSSl:false ExpireIn:0}} MQ:{MQType: MQTT:{Schema: Host: Port:0 Username: Password: KeepAlive:0 ConnectTimeout:0 ProtocolVersion:0 PubQos:0 Qos:0 Order:false ClientIdPrefix: ServerName:core EnableSubShare:false TLSConfig:<nil>} RabbitMQ:{Host: Port:0 Username: Password: VHost: Exchange: Queue:} Kafka:{Brokers:[] Version: GroupID:core GroupIDSuffix: ClientID:core MaxOpenRequests:0 Balancer: Partition:<nil> AutoCommit:<nil> AutoMark:false}} TSDB:{DBType: DBName: Timeout:0 MaxConn:0 MaxOpenConns:0 MaxLifetime:0 MaxIdleConns:0 MaxRetries:0 MaxDelay:0s Influx:{Protocol: Addr: HttpAddr: Username: Password: Sharding:false CreateDatabaseSql: RetentionPolicy: Precision:} Influx2:{Addr: Token: Org: Bucket: Username: Password: UseGZip:<nil> LogLevel:<nil> MaxRetries:<nil> MaxIdleConns:<nil> MaxIdleConnsPerHost:<nil> IdleConnTimeout:<nil> DialTimeout:<nil> TLSHandshakeTimeout:<nil>} TDengine:{DriverName: Addr: Field:{Time: ID:0 Department:0 Tag:0 Nchar:0 Varchar:0} WriteBatchSize:0 CreateDatabaseSql:} Cassandra:{Addrs:[] Username: Password: Consistency:}} Pprof:{Enable:false Prefix: Host: Port:0} Trace:{Enable:false} Operation:{Address: Timeout:0} Lock:{Type:} Cache:{Expire:0s RedisExpire:0s HealthCheck:0s LockTTL:0s} TaskMode:} Forbidden:false FileServerType:local FileServer:/app/fileServer MediaLibraryPath:mediaLibrary SystemDefaultMediaLibrary:systemDefaultMediaLibrary SystemDefaultMediaLibraryMod:false UserFilesPath:userFiles Backup:/app/backup MaxFreeDiskSpaceForBackup:10 CryptoType: Html:/app/html LicenseDir:/app/license SVG:/app/svg Warningkind:[{"alert": true, "fix": true, "handle": true, "id": "ada21497-888f-4f6d-acc3-cb04250d8037", "name": "超限报警", "show": true }, { "alert": true, "fix": true, "handle": true, "id": "61024533-e716-439d-bf3f-e8f2a5c99128", "name": "仪表故障", "show": true }, { "alert": true, "fix": true, "handle": true, "id": "1f849be4-2907-4459-9665-3fda916bf286", "name": "其他报警", "show": true }, { "alert": true, "fix": true, "handle": true, "id": "1d345be4-2567-4764-7890-3ghj278vb342", "name": "数值超限", "show": true }, { "alert": true, "fix": true, "handle": true, "id": "1z875be4-2267-4564-7790-4kij278vb342", "name": "驱动掉线报警", "show": true }, { "alert": true, "fix": true, "handle": true, "id": "1z875xn8-2237-4544-7770-4kix918vb342", "name": "常规表数据报警", "show": true }, { "alert": true, "handle": true, "id": "1z875zt8-2357-4664-7756-4kfg9vzyu672", "name": "采集数据类型不一致", "show": true, "fix": true }] UseLicenseRefreshInterval:60 UseLicenseRefreshTimeout:1m0s}
    �2026/09/07 11:52:24 INFO 创建etcd连接: {Endpoints:[etcd:2379] DialTimeout:10 Username:root Password:dell123 AutoSyncInterval:0s}
    22026/09/07 11:52:24 INFO 配置中心不用配置
    >DEBUG msg=config loaded: /airiot/config/pro.json format: json
    ;2026/09/07 11:52:24 合并配置: {App:{Version: ServerID: ServerName:core RunMode:release EtcdConfig:/airiot/config/pro.json Platform:Multiple Etcd:{Endpoints:[etcd:2379] DialTimeout:10 Username:root Password:dell123 AutoSyncInterval:0s} PrintConfig:false Swagger:true Captcha:{Store:memory Length:4 Width:400 Height:160 RedisDB:10 RedisPrefix:captcha_} Log:{Level:4 Format:text Output:stdout OutputFile:log/service.log MaxAge:0 RotationTime:0 RotationSize:0 RotationCount:0 Syslog:{ServiceName: ProjectId:}} Gorm:{Debug:false LogLevel:3 DBType:postgres MaxLifetime:24 MaxIdleTime:0 MaxOpenConns:20 MaxIdleConns:1 TablePrefix: EnableAutoMigrate:true QueryMaxLength:0 CloseSingleQuote:false MySQL:{Host: Port:0 User: Password: DBName: Parameters:} DM:{Host: Port:0 User: Password: Parameters:} Postgres:{Host:postgres Port:5432 User:root Password:4P1jILKAq5 DBName:postgres SSLMode:disable Parameters: DBType: Distributed:false} Sqlite3:{Path:}} JWTAuth:{Enable:true SigningMethod:HS512 SigningKey:fNfkTmA0jQVp7WQ02T1c Expired:1209600 Store:file FilePath:data/jwt_auth.db RedisDB:10 RedisPrefix:auth_ StoreEnabled:false} Sessions:{StoreType: Key: MaxAge:0 RedisPrefix:} Redis:{Type: Addrs:[redis:6379] Username: Password:4P1jILKAq5 PoolSize:10 Timeout:0 DB:0} MethodOverride:false Server:{Metadata:map[env:local] HealthCheckCycle:0s HTTP:{Host: Port:9000 Timeout:0 CertFile: KeyFile: ShutdownTimeout:0 MaxContentLength:0 MaxLoggerLength:0 IdleTimeout:0s ReadTimeout:0s WriteTimeout:0s} GRPC:{Host: Port:9223 Timeout:0 Limit:0}} Endpoints:[] LocaleDir:/app/configs/locale Root:{UserName:admin} CORS:{Enable:false AllowOrigins:[
    s2026/09/07 11:52:24 INFO 服务启动,运行模式:release,版本号:v4.4.163,进程号:1 tag=main
    �time=2026-09-07T11:52:25.054+08:00 level=ERROR msg="Redis客户端Ping错误: dial tcp: lookup redis on 127.0.0.11:53: no such host" tag=main logType=syslog service=core
    yunmoo
  • hpH 离线
    hpH 离线
    hp
  • hpH 离线
    hpH 离线
    hp
    redis有问题,截图下redis服务日志
    yunmoo
    /1:M 07 Sep 2026 12:27:34.160 * RDB is base AOF
    U1:M 07 Sep 2026 12:27:34.213 * Done loading RDB, keys loaded: 3609, keys expired: 0.
    e1:M 07 Sep 2026 12:27:34.213 * DB loaded from base file appendonly.aof.14816.base.rdb: 0.054 seconds
    �1:M 07 Sep 2026 12:27:34.698 # Bad file format reading the append only file appendonly.aof.14816.incr.aof: make a backup of your AOF file, then use ./redis-check-aof --fix <filename.manifest>
    M1:C 07 Sep 2026 12:28:35.115 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
    o1:C 07 Sep 2026 12:28:35.115 # Redis version=7.0.11, bits=64, commit=00000000, modified=0, pid=1, just started
    41:C 07 Sep 2026 12:28:35.115 # Configuration loaded
    D1:M 07 Sep 2026 12:28:35.116 * monotonic clock: POSIX clock_gettime
    C1:M 07 Sep 2026 12:28:35.116 * Running mode=standalone, port=6379.
    �1:M 07 Sep 2026 12:28:35.116 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
    21:M 07 Sep 2026 12:28:35.116 # Server initialized
    �1:M 07 Sep 2026 12:28:35.116 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
    G1:M 07 Sep 2026 12:28:35.117 * Reading RDB base file on AOF loading...
    F1:M 07 Sep 2026 12:28:35.117 * Loading RDB produced by version 7.0.11
    61:M 07 Sep 2026 12:28:35.117 * RDB age 145914 seconds
    F1:M 07 Sep 2026 12:28:35.117 * RDB memory usage when created 23.41 Mb
    /1:M 07 Sep 2026 12:28:35.117 * RDB is base AOF
    U1:M 07 Sep 2026 12:28:35.171 * Done loading RDB, keys loaded: 3609, keys expired: 0.
    e1:M 07 Sep 2026 12:28:35.171 * DB loaded from base file appendonly.aof.14816.base.rdb: 0.054 seconds
    �1:M 07 Sep 2026 12:28:35.603 # Bad file format reading the append only file appendonly.aof.14816.incr.aof: make a backup of your AOF file, then use ./redis-check-aof --fix <filename.manifest>
    M1:C 07 Sep 2026 12:29:36.052 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
    o1:C 07 Sep 2026 12:29:36.052 # Redis version=7.0.11, bits=64, commit=00000000, modified=0, pid=1, just started
    41:C 07 Sep 2026 12:29:36.052 # Configuration loaded
    D1:M 07 Sep 2026 12:29:36.052 * monotonic clock: POSIX clock_gettime
    C1:M 07 Sep 2026 12:29:36.053 * Running mode=standalone, port=6379.
    �1:M 07 Sep 2026 12:29:36.053 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
    21:M 07 Sep 2026 12:29:36.053 # Server initialized
    �1:M 07 Sep 2026 12:29:36.053 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
    G1:M 07 Sep 2026 12:29:36.053 * Reading RDB base file on AOF loading...
    F1:M 07 Sep 2026 12:29:36.053 * Loading RDB produced by version 7.0.11
    61:M 07 Sep 2026 12:29:36.054 * RDB age 145975 seconds
    F1:M 07 Sep 2026 12:29:36.054 * RDB memory usage when created 23.41 Mb
    /1:M 07 Sep 2026 12:29:36.054 * RDB is base AOF
    U1:M 07 Sep 2026 12:29:36.114 * Done loading RDB, keys loaded: 3609, keys expired: 0.
    e1:M 07 Sep 2026 12:29:36.114 * DB loaded from base file appendonly.aof.14816.base.rdb: 0.060 seconds
    �1:M 07 Sep 2026 12:29:36.558 # Bad file format reading the append only file appendonly.aof.14816.incr.aof: make a backup of your AOF file, then use ./redis-check-aof --fix <filename.manifest>
    M1:C 07 Sep 2026 12:30:36.997 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
    o1:C 07 Sep 2026 12:30:36.997 # Redis version=7.0.11, bits=64, commit=00000000, modified=0, pid=1, just started
    41:C 07 Sep 2026 12:30:36.997 # Configuration loaded
    D1:M 07 Sep 2026 12:30:36.998 * monotonic clock: POSIX clock_gettime
    C1:M 07 Sep 2026 12:30:36.999 * Running mode=standalone, port=6379.
    �1:M 07 Sep 2026 12:30:36.999 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
    21:M 07 Sep 2026 12:30:36.999 # Server initialized
    �1:M 07 Sep 2026 12:30:36.999 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
    G1:M 07 Sep 2026 12:30:36.999 * Reading RDB base file on AOF loading...
    F1:M 07 Sep 2026 12:30:36.999 * Loading RDB produced by version 7.0.11
    61:M 07 Sep 2026 12:30:36.999 * RDB age 146035 seconds
    F1:M 07 Sep 2026 12:30:36.999 * RDB memory usage when created 23.41 Mb
    /1:M 07 Sep 2026 12:30:36.999 * RDB is base AOF
    U1:M 07 Sep 2026 12:30:37.050 * Done loading RDB, keys loaded: 3609, keys expired: 0.
    e1:M 07 Sep 2026 12:30:37.050 * DB loaded from base file appendonly.aof.14816.base.rdb: 0.051 seconds
    �1:M 07 Sep 2026 12:30:37.505 # Bad file format reading the append only file appendonly.aof.14816.incr.aof: make a backup of your AOF file, then use ./redis-check-aof --fix <filename.manifest>
    M1:C 07 Sep 2026 12:31:37.886 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
    o1:C 07 Sep 2026 12:31:37.886 # Redis version=7.0.11, bits=64, commit=00000000, modified=0, pid=1, just started
    41:C 07 Sep 2026 12:31:37.886 # Configuration loaded
    D1:M 07 Sep 2026 12:31:37.886 * monotonic clock: POSIX clock_gettime
    C1:M 07 Sep 2026 12:31:37.887 * Running mode=standalone, port=6379.
    �1:M 07 Sep 2026 12:31:37.887 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
    21:M 07 Sep 2026 12:31:37.887 # Server initialized
    �1:M 07 Sep 2026 12:31:37.887 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
    G1:M 07 Sep 2026 12:31:37.887 * Reading RDB base file on AOF loading...
    F1:M 07 Sep 2026 12:31:37.887 * Loading RDB produced by version 7.0.11
    61:M 07 Sep 2026 12:31:37.887 * RDB age 146096 seconds
    F1:M 07 Sep 2026 12:31:37.887 * RDB memory usage when created 23.41 Mb
    /1:M 07 Sep 2026 12:31:37.887 * RDB is base AOF
    U1:M 07 Sep 2026 12:31:37.945 * Done loading RDB, keys loaded: 3609, keys expired: 0.
    e1:M 07 Sep 2026 12:31:37.945 * DB loaded from base file appendonly.aof.14816.base.rdb: 0.057 seconds
    �1:M 07 Sep 2026 12:31:38.388 # Bad file format reading the append only file appendonly.aof.14816.incr.aof: make a backup of your AOF file, then use ./redis-check-aof --fix <filename.manifest>
    M1:C 07 Sep 2026 12:32:38.748 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
    o1:C 07 Sep 2026 12:32:38.748 # Redis version=7.0.11, bits=64, commit=00000000, modified=0, pid=1, just started
    41:C 07 Sep 2026 12:32:38.748 # Configuration loaded
    D1:M 07 Sep 2026 12:32:38.749 * monotonic clock: POSIX clock_gettime
    C1:M 07 Sep 2026 12:32:38.749 * Running mode=standalone, port=6379.
    �1:M 07 Sep 2026 12:32:38.749 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
    21:M 07 Sep 2026 12:32:38.749 # Server initialized
    �1:M 07 Sep 2026 12:32:38.749 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
    G1:M 07 Sep 2026 12:32:38.750 * Reading RDB base file on AOF loading...
    F1:M 07 Sep 2026 12:32:38.750 * Loading RDB produced by version 7.0.11
    61:M 07 Sep 2026 12:32:38.750 * RDB age 146157 seconds
    F1:M 07 Sep 2026 12:32:38.750 * RDB memory usage when created 23.41 Mb
    /1:M 07 Sep 2026 12:32:38.750 * RDB is base AOF
    U1:M 07 Sep 2026 12:32:38.802 * Done loading RDB, keys loaded: 3609, keys expired: 0.
    e1:M 07 Sep 2026 12:32:38.802 * DB loaded from base file appendonly.aof.14816.base.rdb: 0.053 seconds
    �1:M 07 Sep 2026 12:32:39.244 # Bad file format reading the append only file appendonly.aof.14816.incr.aof: make a backup of your AOF file, then use ./redis-check-aof --fix <filename.manifest>
    M1:C 07 Sep 2026 12:33:39.676 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
    o1:C 07 Sep 2026 12:33:39.676 # Redis version=7.0.11, bits=64, commit=00000000, modified=0, pid=1, just started
    41:C 07 Sep 2026 12:33:39.676 # Configuration loaded
    D1:M 07 Sep 2026 12:33:39.676 * monotonic clock: POSIX clock_gettime
    C1:M 07 Sep 2026 12:33:39.677 * Running mode=standalone, port=6379.
    �1:M 07 Sep 2026 12:33:39.677 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
    21:M 07 Sep 2026 12:33:39.677 # Server initialized
    �1:M 07 Sep 2026 12:33:39.677 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
    G1:M 07 Sep 2026 12:33:39.677 * Reading RDB base file on AOF loading...
    F1:M 07 Sep 2026 12:33:39.677 * Loading RDB produced by version 7.0.11
    61:M 07 Sep 2026 12:33:39.677 * RDB age 146218 seconds
    F1:M 07 Sep 2026 12:33:39.677 * RDB memory usage when created 23.41 Mb
    /1:M 07 Sep 2026 12:33:39.677 * RDB is base AOF
    U1:M 07 Sep 2026 12:33:39.732 * Done loading RDB, keys loaded: 3609, keys expired: 0.
    e1:M 07 Sep 2026 12:33:39.732 * DB loaded from base file appendonly.aof.14816.base.rdb: 0.055 seconds
    �1:M 07 Sep 2026 12:33:40.179 # Bad file format reading the append only file appendonly.aof.14816.incr.aof: make a backup of your AOF file, then use ./redis-check-aof --fix <filename.manifest>
  • hpH 离线
    hpH 离线
    hp
    redis服务的aof文件损坏了,参考这个帖子处理一下就可以了
    https://qa.airiot.tech/topic/25/平台重启后无法登陆-13030-运维管理中redis服务无法启动且日志报错包含aof
