  3. 请问计算值文本数值转浮点数并保留三位小数该怎么实现,我用如下方法不行
    这个位置
    HN_CHEN
    @Zhang书书 [
    "errview": "不显示当前值",
    "id": "syz",
    "logic": {
    "error": null,
    "jsLogic": "{#(0.0000001229*(Math.pow(2079.1,2)-Math.pow({{zxpl1}},2))).toFixed(3)#}",
    "origin": [
    "text": "(0.0000001229*(Math.pow(2079.1,2)-Math.pow("
    "children": [
    "text": ""
    "type": "variable",
    "variable": {
    "defineSchema": {
    "nodeType": "tag",
    "properties": {
    "online": {
    "title": "在线状态",
    "type": "boolean"
    "title": "频率1",
    "type": "object"
    "key": "zxpl1",
    "lastType": "object",
    "path": "tags.zxpl1",
    "title": "数据点.频率1",
    "type": "object"
    "text": ",2))).toFixed(3)"
    "type": "jsLogic"
    "name": "渗压值",
    "policy": "save",
    "setMethod": "custom",
    "timeRange": {
    "count": 1,
    "type": "forward",
    "unit": "m"
    "type": "compute",
    "unit": "Mpa"
    "id": "jrxms",
    "logic": {
    "error": null,
    "jsLogic": "{#{{syz}}10+9#}",
    "origin": [
    "text": ""
    "children": [
    "text": ""
    "type": "variable",
    "variable": {
    "defineSchema": {
    "nodeType": "tag",
    "properties": {
    "online": {
    "title": "在线状态",
    "type": "boolean"
    "title": "渗压值",
    "type": "object"
    "key": "syz",
    "path": "tags.syz",
    "title": "数据点.渗压值",
    "type": "object"
    "text": "10+9"
    "type": "jsLogic"
    "name": "浸润线埋深",
    "policy": "save",
    "type": "compute",
    "unit": "m"
    "id": "parseFloat_syz",
    "logic": {
    "error": null,
    "jsLogic": "{#parseFloat({{syz}})#}",
    "origin": [
    "text": "parseFloat("
    "children": [
    "text": ""
    "type": "variable",
    "variable": {
    "defineSchema": {
    "nodeType": "tag",
    "properties": {
    "online": {
    "title": "在线状态",
    "type": "boolean"
    "title": "渗压值",
    "type": "object"
    "key": "syz",
    "path": "tags.syz",
    "title": "数据点.渗压值",
    "type": "object"
    "text": ")"
    "type": "jsLogic"
    "name": "parseFloat_syz",
    "policy": "save",
    "type": "compute",
    "unit": "Mpa"
    "id": "dd",
    "logic": {
    "error": null,
    "jsLogic": "{#parseFloat((0.0000001229
    (Math.pow(2079.1,2)-Math.pow({{zxpl1}},2))).toFixed(3))#}",
    "origin": [
    "text": "parseFloat((0.0000001229
    "children": [
    "text": ""
    "type": "variable",
    "variable": {
    "defineSchema": {
    "nodeType": "tag",
    "properties": {
    "online": {
    "title": "在线状态",
    "type": "boolean"
    "title": "频率1",
    "type": "object"
    "key": "zxpl1",
    "title": "数据点.频率1",
    "type": "object"
    "text": ",2))).toFixed(3))"
    "type": "jsLogic"
    "name": "dd",
    "policy": "save",
    "type": "compute",
    "unit": "Mpa"
    是改名了吗,之前这个图片我看是叫fdfd
    HN_CHEN
    在 中回复了 Zhang书书 最后由 HN_CHEN 编辑
    在 中回复了 HN_CHEN 最后由 编辑
    @HN_CHEN 频率1这个数据点的小数位是多少?
    HN_CHEN
    @Zhang书书 现在的值是1985.6,小数位数1位
    @HN_CHEN 这个小数位数能改成3吗,还是您这边需求这个数据点只保留一位小数
    HN_CHEN
    @Zhang书书 频率这个数据点我这边要求是一位小数点,最多可能会存在两位小数,跟这个位数有关系么?
    在 中回复了 HN_CHEN 最后由 Zhang书书 编辑
    #22
    @HN_CHEN 是参与计算的数据点位数导致的。因为计算节点没有位数配置,所以用的是数据点的位数。如果你那边不能改动的话,我们这边优化一下,优化好后跟您说
    HN_CHEN
    @Zhang书书 好的,那优化好了告诉我吧。频率这个位数确实没办法改,一般都只有一位
    Zhang书书Z 2 条回复 最后回复
    #24
    @HN_CHEN 可以的
    #25
    @HN_CHEN computed服务发版了 V4.3.13,如果现在查看没有的话,可以过段时间看一下
    HN_CHEN
    我看我这些在线升级都没有了
    #27
    @HN_CHEN 如果之前是可以显示的话,ctrl+f5 清空缓存刷新一下试试
    HN_CHEN
    #28
    @Zhang书书 已经更新了,我是十分钟更新一次,但是现在计算值的点一直到现在快20分钟了都没更新了
    #29
    @HN_CHEN 再更新一下computed服务 V4.3.14版本
    HN_CHEN
    @Zhang书书 可以了,谢谢
