  3. mqtt突然中断上数,这个日志信息是什么意思
    数据点正常上数吗
    J 1 条回复 最后回复
  • J 离线
    J 离线
    Jonathan
    @Zhang书书 重启后正常上数了
    好的,之前可能是驱动加载有点问题,再观察一下看还会不会出现这种问题
    J 1 条回复 最后回复
  • J 离线
    J 离线
    Jonathan
    @Zhang书书 MQTT又突然中断上数据了
    截图一下日志,或者导出也行
    J 2 条回复 最后回复
  • J 离线
    J 离线
    Jonathan
    {"time":"2024-10-31T10:01:22.30593017+08:00","level":"DEBUG","msg":"健康检查: 开始","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
    {"time":"2024-10-31T10:01:22.306283727+08:00","level":"DEBUG","msg":"健康检查: 正常","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
    {"time":"2024-10-31T10:01:22.306294737+08:00","level":"DEBUG","msg":"健康检查: 找到流数量=7","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
    {"time":"2024-10-31T10:01:27.307097551+08:00","level":"DEBUG","msg":"健康检查: 开始","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
    {"time":"2024-10-31T10:01:27.307444304+08:00","level":"DEBUG","msg":"健康检查: 正常","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
    {"time":"2024-10-31T10:01:32.307516671+08:00","level":"DEBUG","msg":"健康检查: 开始","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
    {"time":"2024-10-31T10:01:32.30792531+08:00","level":"DEBUG","msg":"健康检查: 正常","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
    {"time":"2024-10-31T10:01:37.308915938+08:00","level":"DEBUG","msg":"健康检查: 开始","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
    {"time":"2024-10-31T10:01:37.309293078+08:00","level":"DEBUG","msg":"健康检查: 正常","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
    {"time":"2024-10-31T10:01:37.309302947+08:00","level":"DEBUG","msg":"健康检查: 找到流数量=7","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
    {"time":"2024-10-31T10:01:42.310082996+08:00","level":"DEBUG","msg":"健康检查: 开始","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
    {"time":"2024-10-31T10:01:42.310464465+08:00","level":"DEBUG","msg":"健康检查: 正常","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检
  • J 离线
    J 离线
    Jonathan
    在 中回复了 Zhang书书 最后由 Jonathan 编辑
    2024-10-31 09:15:03 INFO 启动驱动 msg="mqtt客户端: 设备表设备汇总 mqtt客户端准备重连..."
    2024-10-31 09:15:03 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=设备汇总"
    2024-10-31 09:15:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=设备汇总, 订阅上报topic=map[dev/301022110281/pub:0]"
    2024-10-31 09:15:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=设备汇总, topic=map[]"
    2024-10-31 09:15:03 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
    2024-10-31 09:25:03 INFO 启动驱动 msg="mqtt客户端: 设备表设备汇总 mqtt客户端准备重连..."
    2024-10-31 09:25:03 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=设备汇总"
    2024-10-31 09:25:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=设备汇总, 订阅上报topic=map[dev/301022110281/pub:0]"
    2024-10-31 09:25:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=设备汇总, topic=map[]"
    2024-10-31 09:25:03 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
    2024-10-31 09:35:03 INFO 启动驱动 msg="mqtt客户端: 设备表设备汇总 mqtt客户端准备重连..."
    2024-10-31 09:35:03 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=设备汇总"
    2024-10-31 09:35:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=设备汇总, 订阅上报topic=map[dev/301022110281/pub:0]"
    2024-10-31 09:35:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=设备汇总, topic=map[]"
    2024-10-31 09:35:03 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
    2024-10-31 09:45:03 INFO 启动驱动 msg="mqtt客户端: 设备表设备汇总 mqtt客户端准备重连..."
    2024-10-31 09:45:03 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=设备汇总"
    2024-10-31 09:45:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=设备汇总, 订阅上报topic=map[dev/301022110281/pub:0]"
    2024-10-31 09:45:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=设备汇总, topic=map[]"
    2024-10-31 09:45:03 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
    2024-10-31 09:55:03 INFO 启动驱动 msg="mqtt客户端: 设备表设备汇总 mqtt客户端准备重连..."
    2024-10-31 09:55:03 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=设备汇总"
    2024-10-31 09:55:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=设备汇总, 订阅上报topic=map[dev/301022110281/pub:0]"
    2024-10-31 09:55:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=设备汇总, topic=map[]"
    2024-10-31 09:55:03 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
    2024-10-31 10:05:03 INFO 启动驱动 msg="mqtt客户端: 设备表设备汇总 mqtt客户端准备重连..."
    2024-10-31 10:05:03 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=设备汇总"
    2024-10-31 10:05:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=设备汇总, 订阅上报topic=map[dev/301022110281/pub:0]"
    2024-10-31 10:05:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=设备汇总, topic=map[]"
    2024-10-31 10:05:03 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
    平台可以外网访问吗,可以的话地址和账号密码私发我一下
    J 1 条回复 最后回复
  • J 离线
    J 离线
    Jonathan
    @Zhang书书 发你了
    驱动实例上这个位置不要填写,两个项目的mqtt冲突了,两个项目的驱动实例上把这个配置都删了, 然后分别重启下驱动
    J 1 条回复 最后回复
  • J 离线
    J 离线
    Jonathan
    @Zhang书书 好的
