mqtt突然中断上数,这个日志信息是什么意思
@Zhang书书 2024-10-29 10:29:28 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=一体化泵站, topic=map[]"
2024-10-29 10:29:32 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
2024-10-29 10:29:36 INFO 启动驱动 msg="mqtt客户端: 设备表一体化泵站 mqtt客户端准备重连..."
2024-10-29 10:29:36 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=一体化泵站"
2024-10-29 10:29:36 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=一体化泵站, 订阅上报topic=map[dev/338223074013/pub:0]"
2024-10-29 10:29:36 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=一体化泵站, topic=map[]"
2024-10-29 10:29:44 INFO 启动驱动 msg="mqtt客户端: 设备表一体化泵站 mqtt客户端准备重连..."
2024-10-29 10:29:44 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
2024-10-29 10:29:44 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=一体化泵站"
2024-10-29 10:29:44 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=一体化泵站, 订阅上报topic=map[dev/338223074013/pub:0]"
2024-10-29 10:29:44 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=一体化泵站, topic=map[]" -
{"time":"2024-10-31T10:01:22.30593017+08:00","level":"DEBUG","msg":"健康检查: 开始","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
{"time":"2024-10-31T10:01:22.306283727+08:00","level":"DEBUG","msg":"健康检查: 正常","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
{"time":"2024-10-31T10:01:22.306294737+08:00","level":"DEBUG","msg":"健康检查: 找到流数量=7","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
{"time":"2024-10-31T10:01:27.307097551+08:00","level":"DEBUG","msg":"健康检查: 开始","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
{"time":"2024-10-31T10:01:27.307444304+08:00","level":"DEBUG","msg":"健康检查: 正常","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
{"time":"2024-10-31T10:01:32.307516671+08:00","level":"DEBUG","msg":"健康检查: 开始","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
{"time":"2024-10-31T10:01:32.30792531+08:00","level":"DEBUG","msg":"健康检查: 正常","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
{"time":"2024-10-31T10:01:37.308915938+08:00","level":"DEBUG","msg":"健康检查: 开始","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
{"time":"2024-10-31T10:01:37.309293078+08:00","level":"DEBUG","msg":"健康检查: 正常","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
{"time":"2024-10-31T10:01:37.309302947+08:00","level":"DEBUG","msg":"健康检查: 找到流数量=7","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
{"time":"2024-10-31T10:01:42.310082996+08:00","level":"DEBUG","msg":"健康检查: 开始","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检查","projectId":"zhihuishuiwu","group":"6718717ab512af2c63f30d08"}
{"time":"2024-10-31T10:01:42.310464465+08:00","level":"DEBUG","msg":"健康检查: 正常","logType":"syslog","service":"zhihuishuiwu-6718717ab512af2c63f30d08-driver-mqtt-client","module":"健康检 -
2024-10-31 09:15:03 INFO 启动驱动 msg="mqtt客户端: 设备表设备汇总 mqtt客户端准备重连..."
2024-10-31 09:15:03 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=设备汇总"
2024-10-31 09:15:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=设备汇总, 订阅上报topic=map[dev/301022110281/pub:0]"
2024-10-31 09:15:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=设备汇总, topic=map[]"
2024-10-31 09:15:03 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
2024-10-31 09:25:03 INFO 启动驱动 msg="mqtt客户端: 设备表设备汇总 mqtt客户端准备重连..."
2024-10-31 09:25:03 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=设备汇总"
2024-10-31 09:25:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=设备汇总, 订阅上报topic=map[dev/301022110281/pub:0]"
2024-10-31 09:25:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=设备汇总, topic=map[]"
2024-10-31 09:25:03 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
2024-10-31 09:35:03 INFO 启动驱动 msg="mqtt客户端: 设备表设备汇总 mqtt客户端准备重连..."
2024-10-31 09:35:03 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=设备汇总"
2024-10-31 09:35:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=设备汇总, 订阅上报topic=map[dev/301022110281/pub:0]"
2024-10-31 09:35:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=设备汇总, topic=map[]"
2024-10-31 09:35:03 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
2024-10-31 09:45:03 INFO 启动驱动 msg="mqtt客户端: 设备表设备汇总 mqtt客户端准备重连..."
2024-10-31 09:45:03 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=设备汇总"
2024-10-31 09:45:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=设备汇总, 订阅上报topic=map[dev/301022110281/pub:0]"
2024-10-31 09:45:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=设备汇总, topic=map[]"
2024-10-31 09:45:03 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
2024-10-31 09:55:03 INFO 启动驱动 msg="mqtt客户端: 设备表设备汇总 mqtt客户端准备重连..."
2024-10-31 09:55:03 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=设备汇总"
2024-10-31 09:55:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=设备汇总, 订阅上报topic=map[dev/301022110281/pub:0]"
2024-10-31 09:55:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=设备汇总, topic=map[]"
2024-10-31 09:55:03 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
2024-10-31 10:05:03 INFO 启动驱动 msg="mqtt客户端: 设备表设备汇总 mqtt客户端准备重连..."
2024-10-31 10:05:03 INFO 启动驱动 msg="mqtt客户端: mqtt客户端已连接! 设备表=设备汇总"
2024-10-31 10:05:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅上报topic, 设备表=设备汇总, 订阅上报topic=map[dev/301022110281/pub:0]"
2024-10-31 10:05:03 INFO 启动驱动 msg="创建mqtt客户端: 订阅指令响应, 设备表=设备汇总, topic=map[]"
2024-10-31 10:05:03 ERROR 启动驱动 msg="mqtt客户端: MQTT连接断开" suggest="检查服务端设备是否关闭了连接"
