空间管理突然打不开了,运维可以打开
18537337117
空间管理突然打不开了,运维可以打开 -
安装目录显示文件特别大,如何优化mongdb的data目录下,和opriention 下面有个10个G的文件
安装目录显示文件特别大,如何优化安装目录显示文件特别大,如何优化
安装包上的空间版和普通版有什么区别安装包上的空间版和普通版有什么区别
页面添加数据图标,预览就发生变形 -
页面添加数据图标,预览就发生变形压缩包传不上,我把代码粘贴上
{"catalog":{},"createTime":"2024-03-05T09:08:18.831+08:00","dashboardModel":null,"draft":"{"params":{"device":"PC","width":"1920px","height":"1080px","runWidth":"1920px","runHeight":"1080px"},"css":{},"script":{},"cells":{"root":{"type":"layoutContainer","params":{"layoutType":"free","free":{"resizeGrid":{"x":1,"y":1},"dragGrid":{"x":1,"y":1},"autoSize":true,"scaleSize":{"width":1920,"height":1080},"deformation":true},"flex":{"flexDirection":"row","flexWrap":"wrap","justifyContent":"flex-start","alignItems":"flex-start","alignContent":"flex-start"},"grid":{"cols":12,"yheight":30,"margin":10,"gridMargin":0},"theme":null},"rootKey":"389F6FB5","configStyle":{"null":{"opa":1,"xs":"repeat","att":"scroll","wid":"100%","hit":"100%","cor":"rgba(4,26,63,1)"}},"layout":{"free":{"layoutContainer_7428":{"width":"100%","height":"10%","x":2,"y":3,"id":"layoutContainer_7428"},"tableView_b5db":{"width":1505,"height":661,"x":0,"y":125,"id":"tableView_b5db"}},"flex":{"layoutContainer_7428":{"width":"100%","height":"10%"},"tableView_b5db":{"width":1684,"height":770}}},"childrenCells":["tableView_b5db","layoutContainer_7428",null,null,null,null]},"layoutContainer_7428":{"type":"layoutContainer","parent":"root","params":{"layoutType":"free","free":{"resizeGrid":{"x":1,"y":1},"dragGrid":{"x":1,"y":1}},"flex":{"flexDirection":"row","flexWrap":"wrap","justifyContent":"flex-start","alignItems":"flex-start","alignContent":"flex-start"},"grid":{"cols":12,"yheight":30,"margin":10,"gridMargin":0},"theme":null,"name":"页头组件"},"configStyle":{"null":{"opa":1,"xs":"repeat","att":"scroll","wid":"100%","hit":"100%","url":"/rest/core/fileServer/mediaLibrary/project_id/页头.png"}},"layout":{"free":{"Text_385d":{"width":321,"height":18,"x":813,"y":18,"id":"Text_385d"},"Time_c601":{"width":148,"height":22,"x":823,"y":28},"Time_c986":{"width":302,"height":22,"x":43,"y":25,"id":"Time_c986"}}},"childrenCells":["Text_385d","Time_c601","Time_c986"]},"Text_385d":{"type":"Text","parent":"layoutContainer_7428","params":{"content":"和协智能车间管理系统"},"configStyle":{".dashboard-text-container .dashboard-text":{"opa":1,"xs":"repeat","att":"scroll","wid":"100%","hit":"100%","cora":"rgba(61,209,220,1)","siz":"30px"},".dashboard-text-container":{"opa":1}}},"Time_c601":{"type":"Time","parent":"layoutContainer_7428","params":{}},"Time_c986":{"type":"Time","parent":"layoutContainer_7428","params":{},"configStyle":{".widgets-time":{"opa":1,"xs":"repeat","att":"scroll","wid":"100%","hit":"100%","siz":"25px","cora":"rgba(61,209,220,1)"}}},"tableView_b5db":{"type":"tableView","parent":"root","params":{"layoutType":"free","free":{"resizeGrid":{"x":1,"y":1},"dragGrid":{"x":1,"y":1},"autoSize":true,"scaleSize":{"width":957,"height":379},"deformation":true},"flex":{"flexDirection":"row","flexWrap":"wrap","justifyContent":"flex-start","alignItems":"flex-start","alignContent":"flex-start"},"grid":{"cols":12,"yheight":30,"margin":10,"gridMargin":0},"table":{"id":"65e530955fcf08b5280e9841","name":"完成率","title":"完成率"},"queryFields":["F_WEU_DECIMAL2","F_WEU_DECIMAL3","F_WEU_DECIMAL4","F_WEU_DECIMAL5","F_WEU_DECIMAL6","F_WEU_TEXT","F_WEU_TEXT1","F_WEU_TEXT7","createTime","creator","modifyTime","modifyUser"],"limit":null,"fieldOrder":{"selected":[{"title":"文本","key":"FNAME"}],"order":{"FNAME":"ASC"}},"tableFilters":[]},"layout":{"free":{"SeriesBar_BD706CD1":{"width":1082,"height":521,"x":187,"y":108,"id":"SeriesBar_BD706CD1"}}},"childrenCells":["SeriesBar_BD706CD1",null]},"SeriesBar_BD706CD1":{"type":"SeriesBar","parent":"tableView_b5db","params":{"option":{"series":[{"type":"bar","color":"linear-gradient(0deg, rgba(195,86,70,0),rgba(60,214,86,1))","markLine":{"data":[]},"showBackground":true,"backgroundStyle":{}}],"xAxis":[{"axisLine":{"lineStyle":{"color":"#333"}},"show":true,"type":"category","axisLabel":{"color":"rgba(47,149,169,1)","fontSize":20},"nameTextStyle":{"axisLine":{"lineStyle":{"color":"#333"}},"show":true,"type":"category","axisLabel":{"color":"rgba(47,149,169,1)"},"fontSize":27}}],"yAxis":[{"axisLine":{"lineStyle":{"color":"#333"}},"show":true,"type":"value","max":1,"axisTick":{"show":false,"lineStyle":{}},"splitLine":{"show":false,"lineStyle":{}}}],"optionType":"xAxis","grid":{"bottom":25},"legend":{"show":true,"type":"plain","orient":"vertical","icon":"arrow"},"tooltip":{"formatter":"{a}: {c}"}},"datasetBind":{"type":"wrap_widget","wrapWidgetType":"data_dataview","params":{"group":[{"field":"F_WEU_TEXT"},{"field":"F_WEU_DECIMAL5"},{"field":"F_WEU_TEXT7"},{"field":"F_WEU_DECIMAL2"},{"field":"F_WEU_DECIMAL3"},{"field":"F_WEU_DECIMAL4"},{"field":"F_WEU_TEXT1"},{"field":"F_WEU_DECIMAL6"}],"columns":[{"name":"部门","expression":"=完成额/部门目标"}]}}},"originKey":"_2175CF80"}},"theme":{},"data":{"customVar":{}},"version":4.1}","focus":false,"id":"65e6708270033370cfa81225","model":{},"modifyTime":"2024-03-06T10:56:36.425+08:00","name":"销售分析","node":{},"table":{},"type":"normal"} -
页面添加数据图标,预览就发生变形浏览器缩放是100%
页面添加数据图标,预览就发生变形
页面添加数据图标,预览就发生变形
页面添加数据图标,预览就发生变形
页面添加数据图标,预览就发生变形页面添加数据图标,预览就发生变形,这是哪的原因
工作表,配置了同步数据,出现不同步现象这会可以了反复配了几次更新了
工作表,配置了同步数据,出现不同步现象现在后台日志也不跳了,还是没数据
工作表,配置了同步数据,出现不同步现象time="2024-03-04T10:33:28+08:00" level=info msg="服务启动,运行模式:release,版本号:v3.0.44,进程号:3128" tag=main version=v3.0.44
time="2024-03-04T10:33:29+08:00" level=info msg="HTTP server is running at :64001." tag=main version=v3.0.44
time="2024-03-04T10:33:30+08:00" level=error msg="项目[default]启动失败:获取工作表数据错误:" -
工作表,配置了同步数据,出现不同步现象按照提示修改字段类型了,还是报错
工作表,配置了同步数据,出现不同步现象time="2024-03-04T10:09:41+08:00" level=debug msg="项目[default]的table:完成率,拼接的query为:select FREALQTY from T_PRD_INSTOCKENTRY"
time="2024-03-04T10:09:41+08:00" level=debug msg="项目[default]的table:完成率,开始执行sql语句"
time="2024-03-04T10:09:41+08:00" level=error msg="项目[default]的table:完成率,插入同步数据到mongo错误:{"code":400,"message":"FREALQTY数字从字符串转换为整型失败:strconv.Atoi: parsing \"7.0000000000\": invalid syntax"}"
time="2024-03-04T10:09:41+08:00" level=debug msg="项目[default]的table:完成率,进入defer即将执行rows.Close"
time="2024-03-04T10:09:41+08:00" level=debug msg="项目[default]的table:完成率,进入defer执行rows.Close成功"
time="2024-03-04T10:09:42+08:00" level=debug msg="项目[default]的table:完成率,拼接的query为:select FREALQTY from T_PRD_INSTOCKENTRY"
time="2024-03-04T10:09:42+08:00" level=debug msg="项目[default]的table:完成率,开始执行sql语句"
time="2024-03-04T10:09:42+08:00" level=error msg="项目[default]的table:完成率,插入同步数据到mongo错误:{"code":400,"message":"FREALQTY数字从字符串转换为整型失败:strconv.Atoi: parsing \"7.0000000000\": invalid syntax"}" -
工作表,配置了同步数据,出现不同步现象
工作表,配置了同步数据,出现不同步现象工作表,配置了同步数据,配置好以后同步了数据,但后来又不同步了,是那的原因?数据库配置参数和连接测试都正常
3.0版本,手机页面打不开是怎么回事?好的,升级后已解决。
