  3. 关于报警管理
关于报警管理
    在 中回复了 Sunny 最后由 编辑
    #21
    @Sunny 首先,excel表格没有布尔类型,所以你用excel打开之后肯定会转换成数值类型,这应该不是我们这边的问题导致的
    其次,可以在代码编辑这个位置直接复制多个,然后修改json数据
    Sunny
    没懂,我直接复制这段代码,但是连id也会跟着一起复制,这个示例能写得再清楚些吗?写完整的两个报警规则的格式示例就行
    "alert": true,
    "blackList": [],
    "delayFull": null,
    "description": "度嘟嘟嘟嘟",
    "disable": true,
    "executionSetting": {
    "cronExpression": "* * * * * ? ",
    "disable": true,
    "executionType": {}
    "fieldName": [
    "d1"
    "handle": true,
    "id": "570f41fe-1dd5-4e85-a24f-41e6e95c8fc3",
    "interval": 360,
    "level": "中",
    "listType": "nolimit",
    "logic": {
    "logic": {
    "var": [
    "var.d1"
    5
    "type": "jsonlogic"
    "separateAlert": true,
    "timeoutSetting": null,
    "timesOfPlay": 1,
    "type": [
    "ada21497-888f-4f6d-acc3-cb04250d8037"
    "warningname": "ceshi2",
    "whiteList": [],
    "broadcastContent": "{{tableDataName}}发生报警,{{desc}}"
    "alert": true,
    "blackList": [],
    "delayFull": null,
    "description": "ceshi2",
    "disable": true,
    "cronExpression": "
    "disable": true,
    "executionType": {}
    "fieldName": [
    "t1"
    "handle": true,
    "id": "570f41fe-1dd5-4e85-a24f-41e6e95c8bb4",
    "interval": 360,
    "level": "中",
    "logic": {
    "logic": {
    "var": [
    "var.t1"
    5
    "type": "jsonlogic"
    "timesOfPlay": 1,
    "type": [
    "warningname": "的点点滴滴",
    "whiteList": [],
    报警规则id改动其中的几个字符,跟第一个不一样就可以,我的d1和t1分别是两个数据点
