更新模块与服务后,PLC产生的新报警,在报警视图中不显示,或者说不触发报警,PLC连接状态正常
v4.3.12DEBUG msg=config loaded: config.yaml format: yaml
&DEBUG msg=config loaded: format:
'DEBUG msg=config loaded: PATH format:
+DEBUG msg=config loaded: HOSTNAME format:
'DEBUG msg=config loaded: HOME format:
1INFO msg=watcher's ctx cancel : context canceled
>DEBUG msg=config loaded: /airiot/config/pro.json format: json
q2024/01/06 12:14:51 INFO 服务启动,运行模式:release,版本号:v4.3.1,进程号:1 tag=main
0time=2024-01-06T12:14:51.875+08:00 level=INFO msg="algorithm http client createConn, {EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:138dd03b-d3ee-4230-d3d2-520feb580bfe SK:138dd03b-d3ee-4230-d3d2-520feb580bfd Timeout:60 Limit:0 Debug:false}"
>time=2024-01-06T12:14:51.875+08:00 level=INFO msg="http create conn,serviceName: algorithm config: {EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:138dd03b-d3ee-4230-d3d2-520feb580bfe SK:138dd03b-d3ee-4230-d3d2-520feb580bfd Timeout:60 Limit:0 Debug:false}"
(time=2024-01-06T12:14:51.969+08:00 level=INFO msg="algorithm grpc client cc, {EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:138dd03b-d3ee-4230-d3d2-520feb580bfe SK:138dd03b-d3ee-4230-d3d2-520feb580bfd Timeout:60 Limit:0 Debug:false}"
@time=2024-01-06T12:14:51.969+08:00 level=INFO msg="grpc create conn,serviceName: algorithm config: {EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:138dd03b-d3ee-4230-d3d2-520feb580bfe SK:138dd03b-d3ee-4230-d3d2-520feb580bfd Timeout:60 Limit:100 Debug:false}"
TWARN msg=[http resolver]Zero endpoint found,refused to write,set: algorithm ins: []
HWARN msg=[resolver] Zero endpoint found,refused to write, instances: []
#time=2024-01-06T12:14:52.108+08:00 level=INFO msg="core grpc client cc, {EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:138dd03b-d3ee-4230-d3d2-520feb580bfe SK:138dd03b-d3ee-4230-d3d2-520feb580bfd Timeout:60 Limit:0 Debug:false}"
Ftime=2024-01-06T12:14:52.108+08:00 level=INFO msg="MQTT 已经连接"
;time=2024-01-06T12:14:52.108+08:00 level=INFO msg="grpc create conn,serviceName: core config: {EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:138dd03b-d3ee-4230-d3d2-520feb580bfe SK:138dd03b-d3ee-4230-d3d2-520feb580bfd Timeout:60 Limit:100 Debug:false}"
/INFO msg=[gRPC] server listening on: [::]:9226
/INFO msg=[HTTP] server listening on: [::]:9000
#time=2024-01-06T12:21:46.423+08:00 level=INFO msg="flow grpc client cc, {EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:138dd03b-d3ee-4230-d3d2-520feb580bfe SK:138dd03b-d3ee-4230-d3d2-520feb580bfd Timeout:60 Limit:0 Debug:false}"
;time=2024-01-06T12:21:46.423+08:00 level=INFO msg="grpc create conn,serviceName: flow config: {EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:138dd03b-d3ee-4230-d3d2-520feb580bfe SK:138dd03b-d3ee-4230-d3d2-520feb580bfd Timeout:60 Limit:100 Debug:false}"
�2024/01/06 12:55:29 [31;1m/go/pkg/mod/git.airiot.tech/core/service.git/v4@v4.2.78/gormdb/gorm.go:162 [35;1mtimeout: context canceled
�[0m[33m[24.292ms] [34;1m[rows:0][0m SELECT "handle","id","status","processed","tableData" FROM "default"."warning" WHERE "recoveryTime" IS NULL AND "tableData" in ('PSZ_3') AND "status" in ('未确认') ORDER BY "time" desc LIMIT 15
rtime=2024-01-06T12:55:29.964+08:00 level=ERROR msg="timeout: context canceled" logType=syslog service=warning
�2024/01/06 16:41:15 [31;1m/go/pkg/mod/git.airiot.tech/core/service.git/v4@v4.2.78/gormdb/gorm.go:159 [35;1mtimeout: context canceled
�[0m[33m[29.536ms] [34;1m[rows:0][0m SELECT count() FROM "default"."warning" WHERE "recoveryTime" IS NULL AND "tableData" in ('PSZ_2') AND "status" in ('未确认')
�[0m[33m[24.232ms] [34;1m[rows:0][0m SELECT count() FROM "default"."warning" WHERE "tableData" in ('PSZ_1') AND "status" in ('未确认') AND "recoveryTime" IS NULL
2024/01/06 16:41:15 [31;1m/go/pkg/mod/git.airiot.tech/core/service.git/v4@v4.2.78/gormdb/gorm.go:159 [35;1mfailed to connect tohost=postgres user=root database=postgres: hostname resolving error (lookup postgres on 127.0.0.11:53: dial udp 127.0.0.11:53: operation was canceled)
�[0m[33m[0.518ms] [34;1m[rows:0][0m SELECT count() FROM "default"."warning" WHERE "recoveryTime" IS NULL AND "tableData" in ('PSZ_3') AND "status" in ('未确认')
rtime=2024-01-06T16:41:15.181+08:00 level=ERROR msg="timeout: context canceled" logType=syslog service=warning
time=2024-01-06T16:41:15.181+08:00 level=ERROR msg="failed to connect tohost=postgres user=root database=postgres: hostname resolving error (lookup postgres on 127.0.0.11:53: dial udp 127.0.0.11:53: operation was canceled)" logType=syslog service=warning
�2024/01/06 17:01:07 [31;1m/go/pkg/mod/git.airiot.tech/core/service.git/v4@v4.2.78/gormdb/gorm.go:162 [35;1mtimeout: context canceled
�[0m[33m[16.353ms] [34;1m[rows:0][0m SELECT "handle","fields","id","status","tableData","processed" FROM "default"."warning" WHERE "status" in ('未确认') AND "recoveryTime" IS NULL AND "tableData" in ('PSZ_2') ORDER BY "time" desc LIMIT 15
rtime=2024-01-06T17:01:07.434+08:00 level=ERROR msg="timeout: context canceled" logType=syslog service=warning
�2024/01/07 11:34:16 [31;1m/go/pkg/mod/git.airiot.tech/core/service.git/v4@v4.2.78/gormdb/gorm.go:159 [35;1mtimeout: context canceled
�[0m[33m[38.226ms] [34;1m[rows:0][0m SELECT count() FROM "default"."warning" WHERE "status" in ('未确认') AND "recoveryTime" IS NULL AND "tableData" in ('PSZ_2')
rtime=2024-01-07T11:34:16.516+08:00 level=ERROR msg="timeout: context canceled" logType=syslog service=warning
�2024/01/08 09:49:40 [31;1m/go/pkg/mod/git.airiot.tech/core/service.git/v4@v4.2.78/gormdb/gorm.go:159 [35;1mtimeout: context canceled
�[0m[33m[92.329ms] [34;1m[rows:0][0m SELECT count(*) FROM "default"."warning" WHERE "tableData" in ('PSZ_3') AND "status" in ('未确认') AND "recoveryTime" IS NULL
rtime=2024-01-08T09:49:40.750+08:00 level=ERROR msg="timeout: context canceled" logType=syslog service=warning
