3.0 多空间Linux版本突然 influx 停止服务了无法启动
3.0 多空间Linux版本,突然 influx 停止服务了,无法启动。
启动服务,提示“操作失败”。按F12可以看到这样的报错信息
"error": {
"code": 400,
"message": "Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused "process_linux.go:449: container init caused \"rootfs_linux.go:58: mounting \\\"/iot/app/airiot/influxdb.conf\\\" to rootfs \\\"/var/lib/docker/overlay2/f7d06f7da23d9db263c9ce1412a32c9a6b75a82091162a5c88f35e8126a92e08/merged\\\" at \\\"/var/lib/docker/overlay2/f7d06f7da23d9db263c9ce1412a32c9a6b75a82091162a5c88f35e8126a92e08/merged/etc/influxdb/influxdb.conf\\\" caused \\\"not a directory\\\"\"": unknown: Are you trying to mount a directory onto a file (or vice-versa)? Check if the specified host path exists and is the expected type"
@net/http.readRequest(0xc0095c7680, 0x0, 0xc00b074e00, 0x0, 0x0)
1 /usr/local/go/src/net/http/request.go:968 +0x8d
Snet/http.(*conn).readRequest(0xc00abae8c0, 0x214b520, 0xc00228dbc0, 0x0, 0x0, 0x0)
1 /usr/local/go/src/net/http/server.go:967 +0x163
>net/http.(*conn).serve(0xc00abae8c0, 0x214b520, 0xc00228dbc0)
2 /usr/local/go/src/net/http/server.go:1819 +0x6ad
$created by net/http.(*Server).Serve
2 /usr/local/go/src/net/http/server.go:2884 +0x2f4
.goroutine 235030729 [IO wait, 15853 minutes]:
Iinternal/poll.runtime_pollWait(0x7f44c1640648, 0x72, 0xffffffffffffffff)
0 /usr/local/go/src/runtime/netpoll.go:182 +0x56
Winternal/poll.(*pollDesc).wait(0xc009730198, 0x72, 0x1000, 0x1000, 0xffffffffffffffff)
= /usr/local/go/src/internal/poll/fd_poll_runtime.go:87 +0x9b
(internal/poll.(*pollDesc).waitRead(...)
7 /usr/local/go/src/internal/poll/fd_poll_runtime.go:92
Tinternal/poll.(*FD).Read(0xc009730180, 0xc020128000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
7 /usr/local/go/src/internal/poll/fd_unix.go:169 +0x19b
dnet.(*netFD).Read(0xc009730180, 0xc020128000, 0x1000, 0x1000, 0xc000d94080, 0xc00a884938, 0x741681)
, /usr/local/go/src/net/fd_unix.go:202 +0x4f
Lnet.(*conn).Read(0xc009d043a8, 0xc020128000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
( /usr/local/go/src/net/net.go:177 +0x69
unet/http.(*connReader).Read(0xc0009531a0, 0xc020128000, 0x1000, 0x1000, 0xc00a884a50, 0xc000953200, 0x5b5c0c0e25400)
1 /usr/local/go/src/net/http/server.go:787 +0x107
#bufio.(*Reader).fill(0xc0028b4480)
- /usr/local/go/src/bufio/bufio.go:100 +0x10f
jbufio.(*Reader).ReadSlice(0xc0028b4480, 0xa, 0x7f44a3d4f0f0, 0xc00a884b00, 0x40bb09, 0xc013462f00, 0x100)
, /usr/local/go/src/bufio/bufio.go:356 +0x3d
hbufio.(*Reader).ReadLine(0xc0028b4480, 0xc00a884b08, 0xc000083500, 0x7f44c65dad98, 0x0, 0x40c398, 0x30)
, /usr/local/go/src/bufio/bufio.go:385 +0x34
dnet/textproto.(*Reader).readLineSlice(0xc000953200, 0xc013462f00, 0xc009730180, 0x0, 0x0, 0x42ce81)
4 /usr/local/go/src/net/textproto/reader.go:55 +0x6f
&net/textproto.(*Reader).ReadLine(...)
. /usr/local/go/src/net/textproto/reader.go:36
@net/http.readRequest(0xc0028b4480, 0x0, 0xc013462f00, 0x0, 0x0)
Snet/http.(*conn).readRequest(0xc0084c81e0, 0x214b520, 0xc000d94000, 0x0, 0x0, 0x0)
>net/http.(*conn).serve(0xc0084c81e0, 0x214b520, 0xc000d94000)
.goroutine 225809842 [IO wait, 25919 minutes]:
Iinternal/poll.runtime_pollWait(0x7f44c1640bf8, 0x72, 0xffffffffffffffff)
Uinternal/poll.(*pollDesc).wait(0xc004b70598, 0x72, 0xf00, 0xff6, 0xffffffffffffffff)
Rinternal/poll.(*FD).Read(0xc004b70580, 0xc00459800a, 0xff6, 0xff6, 0x0, 0x0, 0x0)
Ynet.(*netFD).Read(0xc004b70580, 0xc00459800a, 0xff6, 0xff6, 0xa, 0xc006621938, 0x74165a)
Jnet.(*conn).Read(0xc009d04280, 0xc00459800a, 0xff6, 0xff6, 0x0, 0x0, 0x0)
Unet/http.(*connReader).Read(0xc0087232f0, 0xc00459800a, 0xff6, 0xff6, 0xa, 0x0, 0x0)
#bufio.(*Reader).fill(0xc0024075c0)
`bufio.(*Reader).ReadSlice(0xc0024075c0, 0xa, 0x28, 0xc006621b00, 0x40bb09, 0xc013462400, 0x100)
hbufio.(*Reader).ReadLine(0xc0024075c0, 0xc006621b08, 0xc00020c380, 0x7f44c65db460, 0x0, 0x40c398, 0x30)
dnet/textproto.(*Reader).readLineSlice(0xc008723320, 0xc013462400, 0xc004b70580, 0x0, 0x0, 0x42ce81)
@net/http.readRequest(0xc0024075c0, 0x0, 0xc013462400, 0x0, 0x0)
Snet/http.(*conn).readRequest(0xc007ff2140, 0x214b520, 0xc00bc94300, 0x0, 0x0, 0x0)
>net/http.(*conn).serve(0xc007ff2140, 0x214b520, 0xc00bc94300)
$created by net/http.(Server).Serve
goroutine 249630624 [select, 55 minutes]:
tgithub.com/influxdata/influxdb/services/httpd.(*Handler).serveQuery.func2(0xc00830a0c0, 0xc0001fc150, 0xc00830a000)
L /go/src/github.com/influxdata/influxdb/services/httpd/handler.go:616 +0xa0
Ocreated by github.com/influxdata/influxdb/services/httpd.(*Handler).serveQuery
N /go/src/github.com/influxdata/influxdb/services/httpd/handler.go:613 +0x1303
+goroutine 249630623 [IO wait, 55 minutes]:
Iinternal/poll.runtime_pollWait(0x7f44c1640578, 0x72, 0xffffffffffffffff)
Qinternal/poll.(*pollDesc).wait(0xc0004ea298, 0x72, 0x0, 0x1, 0xffffffffffffffff)
Ninternal/poll.(*FD).Read(0xc0004ea280, 0xc00b704221, 0x1, 0x1, 0x0, 0x0, 0x0)
^net.(*netFD).Read(0xc0004ea280, 0xc00b704221, 0x1, 0x1, 0xc006330098, 0xc000c38f68, 0x47883d)
Fnet.(*conn).Read(0xc000f500e0, 0xc00b704221, 0x1, 0x1, 0x0, 0x0, 0x0)
4net/http.(*connReader).backgroundRead(0xc00b704210)
0 /usr/local/go/src/net/http/server.go:677 +0x58
6created by net/http.(*connReader).startBackgroundRead
0 /usr/local/go/src/net/http/server.go:673 +0xca
