2025-03-14 14:00:31 DEBUG 执行指令 msg="执行指令: 设备表=物联网杀虫灯,设备=njef1qDvEfaDoO982024082706866986,指令={"form":[{"arrayValue":null,"defaultValue":null,"ifRepeat":null,"ioway":"表单写入","mod":null,"name":"adjustLight","objectValue":{"schema":{"form":["style",""],"key":"root","listFields":["style"],"name":"modelProperties","properties":{"style":{"canOrder":false,"config":"选择器","createShow":true,"dataType":"string","descriptionType":"tooltip","editShow":true,"enum1":["on","off"],"enum_title1":["开","关"],"fieldType":"select","invalid":false,"key":"style","listFields":true,"metricStore":false,"need":false,"numRange":null,"selectFace":"flatten","selectType":"single","size":"middle","title":"style","type":"string","widthInForm":"24"}},"required":[],"title":"根对象","treeKey":"root","type":"object"}},"objectValue2":null,"select":null,"select2":null,"tableValue":null,"tableValue2":null,"tag":null,"tagValue":null,"type":"object"}],"formSchema":{"schema":{"form":["style",""],"key":"root","listFields":["style"],"name":"adjustLight","properties":{"style":{"canOrder":false,"config":"选择器","createShow":true,"dataType":"string","descriptionType":"tooltip","editShow":true,"enum1":["on","off"],"enum_title1":["开","关"],"fieldType":"select","invalid":false,"key":"style","listFields":true,"metricStore":false,"need":false,"numRange":null,"selectFace":"flatten","selectType":"single","size":"middle","title":"style","type":"string","widthInForm":"24"}},"required":[],"title":"adjustLight","treeKey":"root","type":"object"}},"id":"adjustLight","name":"adjustLight","ops":[{"key":"adjustLight","param":"adjustLight"}],"params":{"adjustLight":{"style":"on"}},"showName":"杀虫灯开关","tag":null,"title":"adjustLight","writeOut":{"arrayValue":null,"defaultValue":null,"ifRepeat":null,"mod":null,"objectValue":null,"objectValue2":null,"select":null,"select2":null,"tableValue":null,"tableValue2":null,"tag":null,"tagValue":null}}"
2025-03-14 14:00:31 DEBUG 执行指令 msg="执行指令: 表=物联网杀虫灯,设备=njef1qDvEfaDoO982024082706866986,流水号=67d3c5ffc233d4cf4168f344,指令内容={"form":[{"arrayValue":null,"defaultValue":null,"ifRepeat":null,"ioway":"表单写入","mod":null,"name":"adjustLight","objectValue":{"schema":{"form":["style",""],"key":"root","listFields":["style"],"name":"modelProperties","properties":{"style":{"canOrder":false,"config":"选择器","createShow":true,"dataType":"string","descriptionType":"tooltip","editShow":true,"enum1":["on","off"],"enum_title1":["开","关"],"fieldType":"select","invalid":false,"key":"style","listFields":true,"metricStore":false,"need":false,"numRange":null,"selectFace":"flatten","selectType":"single","size":"middle","title":"style","type":"string","widthInForm":"24"}},"required":[],"title":"根对象","treeKey":"root","type":"object"}},"objectValue2":null,"select":null,"select2":null,"tableValue":null,"tableValue2":null,"tag":null,"tagValue":null,"type":"object"}],"formSchema":{"schema":{"form":["style",""],"key":"root","listFields":["style"],"name":"adjustLight","properties":{"style":{"canOrder":false,"config":"选择器","createShow":true,"dataType":"string","descriptionType":"tooltip","editShow":true,"enum1":["on","off"],"enum_title1":["开","关"],"fieldType":"select","invalid":false,"key":"style","listFields":true,"metricStore":false,"need":false,"numRange":null,"selectFace":"flatten","selectType":"single","size":"middle","title":"style","type":"string","widthInForm":"24"}},"required":[],"title":"adjustLight","treeKey":"root","type":"object"}},"id":"adjustLight","name":"adjustLight","ops":[{"key":"adjustLight","param":"adjustLight"}],"params":{"adjustLight":{"style":"on"}},"showName":"杀虫灯开关","tag":null,"title":"adjustLight","writeOut":{"arrayValue":null,"defaultValue":null,"ifRepeat":null,"mod":null,"objectValue":null,"objectValue2":null,"select":null,"select2":null,"tableValue":null,"tableValue2":null,"tag":null,"tagValue":null}}"
2025-03-14 14:19:40 DEBUG 启动驱动 msg="读取设备数据: 设备表=物联网杀虫灯,设备:njef1qDvEfaDoO982024082706866986,周期=3600s"
2025-03-14 14:19:40 DEBUG 启动驱动 msg="存数据点: 设备表=物联网杀虫灯,设备=njef1qDvEfaDoO982024082706866986,数据={"id":"njef1qDvEfaDoO982024082706866986","cid":"","source":"device","fields":{"battery_percent":69,"battery_voltage":11.5,"is_lighting":0,"is_online":1,"latitude":"30.680581650462","led_voltage":0,"longitude":"114.32987566655","outer_temperature":17,"rain_ctl_state":1,"run_day":3},"time":1741933180663,"fieldTypes":null}. 保存数据成功"
2025-03-14 14:46:51 DEBUG 执行指令 msg="执行指令: 设备表=物联网杀虫灯,设备=njef1qDvEfaDoO982024082706866986,指令={"form":[{"arrayValue":null,"defaultValue":null,"ifRepeat":null,"ioway":"表单写入","mod":null,"name":"adjustLight","objectValue":{"schema":{"form":["style",""],"key":"root","listFields":["style"],"name":"modelProperties","properties":{"style":{"canOrder":false,"config":"选择器","createShow":true,"dataType":"string","descriptionType":"tooltip","editShow":true,"enum1":["on","off"],"enum_title1":["开","关"],"fieldType":"select","invalid":false,"key":"style","listFields":true,"metricStore":false,"need":false,"numRange":null,"selectFace":"flatten","selectType":"single","size":"middle","title":"style","type":"string","widthInForm":"24"}},"required":[],"title":"根对象","treeKey":"root","type":"object"}},"objectValue2":null,"select":null,"select2":null,"tableValue":null,"tableValue2":null,"tag":null,"tagValue":null,"type":"object"}],"formSchema":{"schema":{"form":["style",""],"key":"root","listFields":["style"],"name":"adjustLight","properties":{"style":{"canOrder":false,"config":"选择器","createShow":true,"dataType":"string","descriptionType":"tooltip","editShow":true,"enum1":["on","off"],"enum_title1":["开","关"],"fieldType":"select","invalid":false,"key":"style","listFields":true,"metricStore":false,"need":false,"numRange":null,"selectFace":"flatten","selectType":"single","size":"middle","title":"style","type":"string","widthInForm":"24"}},"required":[],"title":"adjustLight","treeKey":"root","type":"object"}},"id":"adjustLight","name":"adjustLight","ops":[{"key":"adjustLight","param":"adjustLight"}],"params":{"adjustLight":{"style":"on"}},"showName":"杀虫灯开关","tag":null,"title":"adjustLight","writeOut":{"arrayValue":null,"defaultValue":null,"ifRepeat":null,"mod":null,"objectValue":null,"objectValue2":null,"select":null,"select2":null,"tableValue":null,"tableValue2":null,"tag":null,"tagValue":null}}"
2025-03-14 14:46:51 DEBUG 执行指令 msg="执行指令: 表=物联网杀虫灯,设备=njef1qDvEfaDoO982024082706866986,流水号=67d3d0dbc233d4cf4168f347,指令内容={"form":[{"arrayValue":null,"defaultValue":null,"ifRepeat":null,"ioway":"表单写入","mod":null,"name":"adjustLight","objectValue":{"schema":{"form":["style",""],"key":"root","listFields":["style"],"name":"modelProperties","properties":{"style":{"canOrder":false,"config":"选择器","createShow":true,"dataType":"string","descriptionType":"tooltip","editShow":true,"enum1":["on","off"],"enum_title1":["开","关"],"fieldType":"select","invalid":false,"key":"style","listFields":true,"metricStore":false,"need":false,"numRange":null,"selectFace":"flatten","selectType":"single","size":"middle","title":"style","type":"string","widthInForm":"24"}},"required":[],"title":"根对象","treeKey":"root","type":"object"}},"objectValue2":null,"select":null,"select2":null,"tableValue":null,"tableValue2":null,"tag":null,"tagValue":null,"type":"object"}],"formSchema":{"schema":{"form":["style",""],"key":"root","listFields":["style"],"name":"adjustLight","properties":{"style":{"canOrder":false,"config":"选择器","createShow":true,"dataType":"string","descriptionType":"tooltip","editShow":true,"enum1":["on","off"],"enum_title1":["开","关"],"fieldType":"select","invalid":false,"key":"style","listFields":true,"metricStore":false,"need":false,"numRange":null,"selectFace":"flatten","selectType":"single","size":"middle","title":"style","type":"string","widthInForm":"24"}},"required":[],"title":"adjustLight","treeKey":"root","type":"object"}},"id":"adjustLight","name":"adjustLight","ops":[{"key":"adjustLight","param":"adjustLight"}],"params":{"adjustLight":{"style":"on"}},"showName":"杀虫灯开关","tag":null,"title":"adjustLight","writeOut":{"arrayValue":null,"defaultValue":null,"ifRepeat":null,"mod":null,"objectValue":null,"objectValue2":null,"select":null,"select2":null,"tableValue":null,"tableValue2":null,"tag":null,"tagValue":null}}"
