  3. AB PLC驱动 在服务器重启后 需要重启服务才能连上PLC
    yfyfzw
    服务器重启后
    AB PLC驱动不能自动连接到PLC(等待24小时也不能自动连上)
    需要重启AB PLC 驱动 服务后 才能正常连接
    服务重启前
    重启后就正常了
    截图看一下驱动实例上的配置是如何填写的
    yfyfzw
    配置是你们后端同事帮忙做的
    这个问题我们这边开发同事正在排查,等优化之后我在这里跟您说~
    yfyfzw
    服务器重启后,驱动需要手动重启才能运行的问题,应该不只是AB PLC驱动有这个问题,感觉海康摄像头驱动,httpserver好像也有这个问题
    httpserver驱动服务重启前,也是这样吗
    把安装目录下的 lib\pm2\logs 里面的 http-server 的日志发一下
    yfyfzw
    2025/01/08 10:17:17 INFO 版本: v4.1.13 module=执行指令
    {"time":"2025-01-08T10:17:17.0357924+08:00","level":"INFO","msg":"启动配置={ServiceID:67501da4a9045af51870e5f2 GroupID:67501da4a9045af51870e5f2 Project:default Driver:{ID:http-server-driver Name:Http-Server} DriverGrpc:{Host:127.0.0.1 Port:9224 Health:{RequestTime:10s Retry:3} Stream:{Heartbeat:30s} WaitTime:5s Timeout:10m0s Limit:100} Log:{Level:4 Format:json Output:stdout OutputFile: MaxAge:0 RotationTime:0 RotationSize:0 RotationCount:0 Syslog:{ServiceName:default-67501da4a9045af51870e5f2-http-server-driver ProjectId:default}} MQ:{Type:mqtt Timeout:1m0s MQTT:{Host:127.0.0.1 Port:1883 Username:admin Password:ENhQ3wxeIO KeepAlive:60 ConnectTimeout:20 ProtocolVersion:4} Rabbit:{Host:rabbit Port:5672 Username:admin Password:public VHost: Exchange: Queue:} Kafka:{Brokers:[kafka:9092] Version: GroupID: ClientID: MaxOpenRequests:0 Balancer: Partition:<nil> AutoCommit:<nil>}} Pprof:{Enable:false Host: Port:} EtcdConfig: Etcd:{Endpoints:[127.0.0.1:2379] DialTimeout:5 Username:root Password:dell123 AutoSyncInterval:0s}}"}
    {"time":"2025-01-08T10:17:17.03679+08:00","level":"INFO","msg":"INFO 监听端口: 2886 module=执行指令"}
    {"time":"2025-01-08T10:17:17.03679+08:00","level":"INFO","msg":"MQTT 已连接"}
    DEBUG msg=config loaded: /airiot/config/pro.json format: json
    DEBUG msg=config loaded: ALLUSERSPROFILE format:
    DEBUG msg=config loaded: APPDATA format:
    DEBUG msg=config loaded: args format:
    DEBUG msg=config loaded: AutInstLog format:
    DEBUG msg=config loaded: automation format:
    DEBUG msg=config loaded: autorestart format:
    DEBUG msg=config loaded: axm_actions format:
    DEBUG msg=config loaded: axm_dynamic format:
    DEBUG msg=config loaded: axm_monitor format:
    DEBUG msg=config loaded: axm_options format:
    DEBUG msg=config loaded: CommonProgramFiles format:
    DEBUG msg=config loaded: CommonProgramFiles(x86) format:
    DEBUG msg=config loaded: CommonProgramW6432 format:
    DEBUG msg=config loaded: COMPUTERNAME format:
    DEBUG msg=config loaded: ComSpec format:
    DEBUG msg=config loaded: CPOLAR_HOME format:
    DEBUG msg=config loaded: created_at format:
    DEBUG msg=config loaded: cwd format:
    DEBUG msg=config loaded: DriverData format:
    DEBUG msg=config loaded: env format:
    DEBUG msg=config loaded: exec_interpreter format:
    DEBUG msg=config loaded: exec_mode format:
    DEBUG msg=config loaded: FLEXID_LIBRARY_PATH format:
    DEBUG msg=config loaded: instances format:
    DEBUG msg=config loaded: instance_var format:
    DEBUG msg=config loaded: kill_retry_time format:
    DEBUG msg=config loaded: kill_timeout format:
    DEBUG msg=config loaded: LOCALAPPDATA format:
    DEBUG msg=config loaded: log_file format:
    DEBUG msg=config loaded: merge_logs format:
    DEBUG msg=config loaded: MQ.MQTT.PASSWORD format:
    DEBUG msg=config loaded: name format:
    DEBUG msg=config loaded: namespace format:
    DEBUG msg=config loaded: NODE_APP_INSTANCE format:
    DEBUG msg=config loaded: node_args format:
    DEBUG msg=config loaded: NODE_CHANNEL_FD format:
    DEBUG msg=config loaded: NODE_CHANNEL_SERIALIZATION_MODE format:
    DEBUG msg=config loaded: NUMBER_OF_PROCESSORS format:
    DEBUG msg=config loaded: OPENSSL_CONF format:
    DEBUG msg=config loaded: OS format:
    DEBUG msg=config loaded: Path format:
    DEBUG msg=config loaded: PATHEXT format:
    DEBUG msg=config loaded: pid_file format:
    DEBUG msg=config loaded: PM2_HOME format:
    DEBUG msg=config loaded: PM2_INSTALL_DIRECTORY format:
    DEBUG msg=config loaded: PM2_JSON_PROCESSING format:
    DEBUG msg=config loaded: PM2_SERVICE_DIRECTORY format:
    DEBUG msg=config loaded: PM2_USAGE format:
    DEBUG msg=config loaded: pmx format:
    DEBUG msg=config loaded: pmx_module format:
    DEBUG msg=config loaded: pm_cwd format:
    DEBUG msg=config loaded: pm_exec_path format:
    DEBUG msg=config loaded: pm_id format:
    DEBUG msg=config loaded: pm_log_path format:
    DEBUG msg=config loaded: pm_pid_path format:
    DEBUG msg=config loaded: pm_uptime format:
    DEBUG msg=config loaded: PROCESSOR_ARCHITECTURE format:
    DEBUG msg=config loaded: PROCESSOR_IDENTIFIER format:
    DEBUG msg=config loaded: PROCESSOR_LEVEL format:
    DEBUG msg=config loaded: PROCESSOR_REVISION format:
    DEBUG msg=config loaded: production_mq__mqtt__password format:
    DEBUG msg=config loaded: ProgramData format:
    DEBUG msg=config loaded: ProgramFiles format:
    DEBUG msg=config loaded: ProgramFiles(x86) format:
    DEBUG msg=config loaded: ProgramW6432 format:
    DEBUG msg=config loaded: PSModulePath format:
    DEBUG msg=config loaded: PUBLIC format:
    DEBUG msg=config loaded: restart_delay format:
    DEBUG msg=config loaded: restart_time format:
    DEBUG msg=config loaded: S7TMP format:
    DEBUG msg=config loaded: script format:
    DEBUG msg=config loaded: Simatic_OAM format:
    DEBUG msg=config loaded: Simatic_OAM_DATA format:
    DEBUG msg=config loaded: status format:
    DEBUG msg=config loaded: SystemDrive format:
    DEBUG msg=config loaded: SystemRoot format:
    DEBUG msg=config loaded: TEMP format:
    DEBUG msg=config loaded: TigerKin format:
    DEBUG msg=config loaded: TMP format:
    DEBUG msg=config loaded: treekill format:
    DEBUG msg=config loaded: unique_id format:
    DEBUG msg=config loaded: unstable_restarts format:
    DEBUG msg=config loaded: updateEnv format:
    DEBUG msg=config loaded: USERDOMAIN format:
    DEBUG msg=config loaded: USERNAME format:
    DEBUG msg=config loaded: USERPROFILE format:
    DEBUG msg=config loaded: version format:
    DEBUG msg=config loaded: vizion format:
    DEBUG msg=config loaded: vizion_running format:
    DEBUG msg=config loaded: wait_ready format:
    DEBUG msg=config loaded: watch format:
    DEBUG msg=config loaded: windir format:
    DEBUG msg=config loaded: windowsHide format:
    {"time":"2025-01-08T10:17:17.1582906+08:00","level":"INFO","msg":"algorithm http client createConn, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:8094acdb-8135-4c95-be4d-e828b3b1775d SK:8cd1818a-df64-4ddd-910a-65f9e08b84d4 Timeout:15 Limit:0 Debug:false}"}
    {"time":"2025-01-08T10:17:17.1582906+08:00","level":"INFO","msg":"http create conn,serviceName: algorithm config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:8094acdb-8135-4c95-be4d-e828b3b1775d SK:8cd1818a-df64-4ddd-910a-65f9e08b84d4 Timeout:15 Limit:0 Debug:false}"}
    {"time":"2025-01-08T10:17:17.2280619+08:00","level":"INFO","msg":"algorithm grpc client cc, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:8094acdb-8135-4c95-be4d-e828b3b1775d SK:8cd1818a-df64-4ddd-910a-65f9e08b84d4 Timeout:15 Limit:0 Debug:false}"}
    {"time":"2025-01-08T10:17:17.2280619+08:00","level":"INFO","msg":"grpc create conn,serviceName: algorithm config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:8094acdb-8135-4c95-be4d-e828b3b1775d SK:8cd1818a-df64-4ddd-910a-65f9e08b84d4 Timeout:15 Limit:100 Debug:false}"}
    INFO msg=watcher's ctx cancel : context canceled
    {"time":"2025-01-08T10:17:17.2921409+08:00","level":"INFO","msg":"连接driver: 配置={Host:127.0.0.1 Port:9224 Health:{RequestTime:10s Retry:3} Stream:{Heartbeat:30s} WaitTime:5s Timeout:10m0s Limit:100}","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.2921409+08:00","level":"INFO","msg":"健康检查: 启动","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.2921409+08:00","level":"INFO","msg":"httpProxy: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.2921409+08:00","level":"INFO","msg":"schema: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.2921409+08:00","level":"INFO","msg":"start: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.2921409+08:00","level":"INFO","msg":"执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.2921409+08:00","level":"INFO","msg":"写数据点: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.2921409+08:00","level":"INFO","msg":"批量执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.2921409+08:00","level":"INFO","msg":"调试: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.293534+08:00","level":"INFO","msg":"httpProxy: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.293534+08:00","level":"INFO","msg":"schema: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.293534+08:00","level":"INFO","msg":"start: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.293534+08:00","level":"INFO","msg":"执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.293534+08:00","level":"INFO","msg":"写数据点: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.293534+08:00","level":"INFO","msg":"批量执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.293534+08:00","level":"INFO","msg":"调试: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.306266+08:00","level":"INFO","msg":"启动驱动","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.3232922+08:00","level":"INFO","msg":"表接口已注册: 设备表=HttpServer,请求路径=/http-server-driver/count,请求方式=[GET POST PUT]","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","table":"HttpServer","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:17.3232922+08:00","level":"INFO","msg":"表接口注册: 设备表=HttpServer,请求路径=/count,请求方式=[GET POST PUT]","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","table":"HttpServer","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:17:20.3372213+08:00","level":"INFO","msg":"启动驱动: 驱动已启动, listening on :2886","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:30:20.6520627+08:00","level":"INFO","msg":"启动驱动","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:30:20.6520627+08:00","level":"INFO","msg":"停止驱动","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:30:20.6526325+08:00","level":"INFO","msg":"驱动已停止","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:30:20.6666603+08:00","level":"INFO","msg":"表接口已注册: 设备表=HttpServer,请求路径=/http-server-driver/count,请求方式=[GET POST PUT]","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","table":"HttpServer","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:30:20.6666603+08:00","level":"INFO","msg":"表接口注册: 设备表=HttpServer,请求路径=/count,请求方式=[GET POST PUT]","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","table":"HttpServer","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T10:30:23.6763279+08:00","level":"INFO","msg":"启动驱动: 驱动已启动, listening on :2886","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    2025/01/08 13:36:25 INFO 版本: v4.1.13 module=执行指令
    {"time":"2025-01-08T13:36:25.9599701+08:00","level":"INFO","msg":"启动配置={ServiceID:67501da4a9045af51870e5f2 GroupID:67501da4a9045af51870e5f2 Project:default Driver:{ID:http-server-driver Name:Http-Server} DriverGrpc:{Host:127.0.0.1 Port:9224 Health:{RequestTime:10s Retry:3} Stream:{Heartbeat:30s} WaitTime:5s Timeout:10m0s Limit:100} Log:{Level:4 Format:json Output:stdout OutputFile: MaxAge:0 RotationTime:0 RotationSize:0 RotationCount:0 Syslog:{ServiceName:default-67501da4a9045af51870e5f2-http-server-driver ProjectId:default}} MQ:{Type:mqtt Timeout:1m0s MQTT:{Host:127.0.0.1 Port:1883 Username:admin Password:ENhQ3wxeIO KeepAlive:60 ConnectTimeout:20 ProtocolVersion:4} Rabbit:{Host:rabbit Port:5672 Username:admin Password:public VHost: Exchange: Queue:} Kafka:{Brokers:[kafka:9092] Version: GroupID: ClientID: MaxOpenRequests:0 Balancer: Partition:<nil> AutoCommit:<nil>}} Pprof:{Enable:false Host: Port:} EtcdConfig: Etcd:{Endpoints:[127.0.0.1:2379] DialTimeout:5 Username:root Password:dell123 AutoSyncInterval:0s}}"}
    {"time":"2025-01-08T13:36:25.9618442+08:00","level":"INFO","msg":"INFO 监听端口: 2886 module=执行指令"}
    {"time":"2025-01-08T13:36:25.9628398+08:00","level":"INFO","msg":"MQTT 已连接"}
    {"time":"2025-01-08T13:36:26.2323631+08:00","level":"INFO","msg":"algorithm http client createConn, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:8094acdb-8135-4c95-be4d-e828b3b1775d SK:8cd1818a-df64-4ddd-910a-65f9e08b84d4 Timeout:15 Limit:0 Debug:false}"}
    {"time":"2025-01-08T13:36:26.2323631+08:00","level":"INFO","msg":"http create conn,serviceName: algorithm config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:8094acdb-8135-4c95-be4d-e828b3b1775d SK:8cd1818a-df64-4ddd-910a-65f9e08b84d4 Timeout:15 Limit:0 Debug:false}"}
    {"time":"2025-01-08T13:36:26.3267272+08:00","level":"INFO","msg":"algorithm grpc client cc, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:8094acdb-8135-4c95-be4d-e828b3b1775d SK:8cd1818a-df64-4ddd-910a-65f9e08b84d4 Timeout:15 Limit:0 Debug:false}"}
    {"time":"2025-01-08T13:36:26.3267272+08:00","level":"INFO","msg":"grpc create conn,serviceName: algorithm config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:8094acdb-8135-4c95-be4d-e828b3b1775d SK:8cd1818a-df64-4ddd-910a-65f9e08b84d4 Timeout:15 Limit:100 Debug:false}"}
    {"time":"2025-01-08T13:36:26.4705992+08:00","level":"INFO","msg":"连接driver: 配置={Host:127.0.0.1 Port:9224 Health:{RequestTime:10s Retry:3} Stream:{Heartbeat:30s} WaitTime:5s Timeout:10m0s Limit:100}","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.4705992+08:00","level":"INFO","msg":"健康检查: 启动","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.4705992+08:00","level":"INFO","msg":"httpProxy: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.4705992+08:00","level":"INFO","msg":"执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.4705992+08:00","level":"INFO","msg":"schema: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.4705992+08:00","level":"INFO","msg":"start: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.4705992+08:00","level":"INFO","msg":"批量执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.4705992+08:00","level":"INFO","msg":"写数据点: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.4705992+08:00","level":"INFO","msg":"调试: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.5318981+08:00","level":"INFO","msg":"httpProxy: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.5324006+08:00","level":"INFO","msg":"执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.5324006+08:00","level":"INFO","msg":"schema: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.5324006+08:00","level":"INFO","msg":"start: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.5324006+08:00","level":"INFO","msg":"批量执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.5324006+08:00","level":"INFO","msg":"写数据点: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:26.5324006+08:00","level":"INFO","msg":"调试: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:36.5995068+08:00","level":"ERROR","msg":"健康检查: code=Start,错误=请求错误: rpc error: code = Unavailable desc = last connection error: connection error: desc = "transport: Error while dialing: dial tcp 127.0.0.1:9223: connectex: No connection could be made because the target machine actively refused it."","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"健康检查","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:36.5995762+08:00","level":"ERROR","msg":"httpProxy: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:36.5995762+08:00","level":"ERROR","msg":"执行指令: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:36.5995762+08:00","level":"ERROR","msg":"schema: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:36.5995762+08:00","level":"ERROR","msg":"写数据点: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:36.5995762+08:00","level":"ERROR","msg":"批量执行指令: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:36.5995762+08:00","level":"ERROR","msg":"start: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:36.5995762+08:00","level":"ERROR","msg":"调试: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:41.6341502+08:00","level":"INFO","msg":"写数据点: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6341502+08:00","level":"INFO","msg":"schema: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6341502+08:00","level":"INFO","msg":"调试: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6341502+08:00","level":"INFO","msg":"批量执行指令: stream创建错
    yfyfzw
    误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6694023+08:00","level":"INFO","msg":"httpProxy: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6694023+08:00","level":"INFO","msg":"连接driver: 配置={Host:127.0.0.1 Port:9224 Health:{RequestTime:10s Retry:3} Stream:{Heartbeat:30s} WaitTime:5s Timeout:10m0s Limit:100}","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6699172+08:00","level":"INFO","msg":"健康检查: 启动","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6709084+08:00","level":"INFO","msg":"httpProxy: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6709084+08:00","level":"INFO","msg":"start: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6709084+08:00","level":"INFO","msg":"执行指令: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6709084+08:00","level":"INFO","msg":"schema: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6709084+08:00","level":"INFO","msg":"start: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6709084+08:00","level":"INFO","msg":"执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6709084+08:00","level":"INFO","msg":"写数据点: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6709084+08:00","level":"INFO","msg":"批量执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6709084+08:00","level":"INFO","msg":"调试: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6829857+08:00","level":"INFO","msg":"httpProxy: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6829857+08:00","level":"INFO","msg":"schema: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6829857+08:00","level":"INFO","msg":"start: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6829857+08:00","level":"INFO","msg":"执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6829857+08:00","level":"INFO","msg":"写数据点: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.683494+08:00","level":"INFO","msg":"批量执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.683513+08:00","level":"INFO","msg":"调试: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6865127+08:00","level":"ERROR","msg":"健康检查: code=Start,错误=请求错误: rpc error: code = Unavailable desc = last connection error: connection error: desc = "transport: Error while dialing: dial tcp 127.0.0.1:9223: connectex: No connection could be made because the target machine actively refused it."","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"健康检查","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:41.6865127+08:00","level":"ERROR","msg":"写数据点: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:41.6865127+08:00","level":"ERROR","msg":"批量执行指令: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:41.6865127+08:00","level":"ERROR","msg":"调试: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:41.6865127+08:00","level":"ERROR","msg":"httpProxy: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:41.6865127+08:00","level":"ERROR","msg":"schema: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:41.6865127+08:00","level":"ERROR","msg":"start: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:41.6865127+08:00","level":"ERROR","msg":"执行指令: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:46.6902861+08:00","level":"INFO","msg":"写数据点: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6902861+08:00","level":"INFO","msg":"连接driver: 配置={Host:127.0.0.1 Port:9224 Health:{RequestTime:10s Retry:3} Stream:{Heartbeat:30s} WaitTime:5s Timeout:10m0s Limit:100}","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6902861+08:00","level":"INFO","msg":"健康检查: 启动","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6902861+08:00","level":"INFO","msg":"httpProxy: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6902861+08:00","level":"INFO","msg":"执行指令: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6902861+08:00","level":"INFO","msg":"start: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6902861+08:00","level":"INFO","msg":"schema: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6902861+08:00","level":"INFO","msg":"httpProxy: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6902861+08:00","level":"INFO","msg":"调试: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6902861+08:00","level":"INFO","msg":"批量执行指令: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6912836+08:00","level":"INFO","msg":"schema: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6912836+08:00","level":"INFO","msg":"start: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6912836+08:00","level":"INFO","msg":"执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6912836+08:00","level":"INFO","msg":"写数据点: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6912836+08:00","level":"INFO","msg":"批量执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6912836+08:00","level":"INFO","msg":"调试: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6952376+08:00","level":"INFO","msg":"httpProxy: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6952376+08:00","level":"INFO","msg":"写数据点: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6952376+08:00","level":"INFO","msg":"批量执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6952376+08:00","level":"INFO","msg":"调试: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6952376+08:00","level":"INFO","msg":"start: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6952376+08:00","level":"INFO","msg":"schema: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:46.6952376+08:00","level":"INFO","msg":"执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:51.6979405+08:00","level":"ERROR","msg":"健康检查: 服务端未找到本驱动服务","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"健康检查","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:51.6980148+08:00","level":"ERROR","msg":"httpProxy: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:51.6980148+08:00","level":"ERROR","msg":"执行指令: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:51.6980148+08:00","level":"ERROR","msg":"写数据点: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:51.6980148+08:00","level":"ERROR","msg":"批量执行指令: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:51.6980148+08:00","level":"ERROR","msg":"调试: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:51.6980148+08:00","level":"ERROR","msg":"start: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:51.6980148+08:00","level":"ERROR","msg":"schema: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"httpProxy: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"连接driver: 配置={Host:127.0.0.1 Port:9224 Health:{RequestTime:10s Retry:3} Stream:{Heartbeat:30s} WaitTime:5s Timeout:10m0s Limit:100}","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"健康检查: 启动","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"httpProxy: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"schema: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"start: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"调试: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"批量执行指令: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"写数据点: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"执行指令: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"schema: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"start: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"写数据点: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"批量执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.6994877+08:00","level":"INFO","msg":"调试: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.7024802+08:00","level":"INFO","msg":"httpProxy: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.7024802+08:00","level":"INFO","msg":"schema: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.7024802+08:00","level":"INFO","msg":"start: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.7024802+08:00","level":"INFO","msg":"执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.7024802+08:00","level":"INFO","msg":"写数据点: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.7024802+08:00","level":"INFO","msg":"批量执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.7024802+08:00","level":"INFO","msg":"调试: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.7044742+08:00","level":"ERROR","msg":"健康检查: code=Start,错误=请求错误: rpc error: code = Unavailable desc = last connection error: connection error: desc = "transport: Error while dialing: dial tcp 127.0.0.1:9223: connectex: No connection could be made because the target machine actively refused it."","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"健康检查","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:36:56.7044742+08:00","level":"ERROR","msg":"批量执行指令: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:56.7044742+08:00","level":"ERROR","msg":"调试: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:56.7044742+08:00","level":"ERROR","msg":"httpProxy: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:56.7044742+08:00","level":"ERROR","msg":"schema: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:56.7044742+08:00","level":"ERROR","msg":"start: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:56.7044742+08:00","level":"ERROR","msg":"执行指令: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:36:56.7044742+08:00","level":"ERROR","msg":"写数据点: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Canceled desc = grpc: the client connection is closing"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"批量执行指令: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"连接driver: 配置={Host:127.0.0.1 Port:9224 Health:{RequestTime:10s Retry:3} Stream:{Heartbeat:30s} WaitTime:5s Timeout:10m0s Limit:100}","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"健康检查: 启动","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"httpProxy: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"写数据点: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"执行指令: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"start: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"schema: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"httpProxy: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"调试: 通过上下文关闭stream检查","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"schema: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"start: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"写数据点: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"批量执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7088896+08:00","level":"INFO","msg":"调试: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7157188+08:00","level":"INFO","msg":"httpProxy: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7209828+08:00","level":"INFO","msg":"执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7209828+08:00","level":"INFO","msg":"schema: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7209828+08:00","level":"INFO","msg":"start: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7209828+08:00","level":"INFO","msg":"批量执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:37:01.7209828+08:00","level":"INFO","msg":"写数据点: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    yfyfzw
    {"time":"2025-01-08T13:37:01.7209828+08:00","level":"INFO","msg":"调试: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    2025/01/08 13:38:46 INFO 版本: v4.1.13 module=执行指令
    {"time":"2025-01-08T13:38:46.583987+08:00","level":"INFO","msg":"启动配置={ServiceID:67501da4a9045af51870e5f2 GroupID:67501da4a9045af51870e5f2 Project:default Driver:{ID:http-server-driver Name:Http-Server} DriverGrpc:{Host:127.0.0.1 Port:9224 Health:{RequestTime:10s Retry:3} Stream:{Heartbeat:30s} WaitTime:5s Timeout:10m0s Limit:100} Log:{Level:4 Format:json Output:stdout OutputFile: MaxAge:0 RotationTime:0 RotationSize:0 RotationCount:0 Syslog:{ServiceName:default-67501da4a9045af51870e5f2-http-server-driver ProjectId:default}} MQ:{Type:mqtt Timeout:1m0s MQTT:{Host:127.0.0.1 Port:1883 Username:admin Password:ENhQ3wxeIO KeepAlive:60 ConnectTimeout:20 ProtocolVersion:4} Rabbit:{Host:rabbit Port:5672 Username:admin Password:public VHost: Exchange: Queue:} Kafka:{Brokers:[kafka:9092] Version: GroupID: ClientID: MaxOpenRequests:0 Balancer: Partition:<nil> AutoCommit:<nil>}} Pprof:{Enable:false Host: Port:} EtcdConfig: Etcd:{Endpoints:[127.0.0.1:2379] DialTimeout:5 Username:root Password:dell123 AutoSyncInterval:0s}}"}
    {"time":"2025-01-08T13:38:46.5881597+08:00","level":"INFO","msg":"INFO 监听端口: 2886 module=执行指令"}
    {"time":"2025-01-08T13:38:46.5881597+08:00","level":"INFO","msg":"MQTT 已连接"}
    {"time":"2025-01-08T13:38:46.9591262+08:00","level":"INFO","msg":"algorithm http client createConn, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:8094acdb-8135-4c95-be4d-e828b3b1775d SK:8cd1818a-df64-4ddd-910a-65f9e08b84d4 Timeout:15 Limit:0 Debug:false}"}
    {"time":"2025-01-08T13:38:46.9591262+08:00","level":"INFO","msg":"http create conn,serviceName: algorithm config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:8094acdb-8135-4c95-be4d-e828b3b1775d SK:8cd1818a-df64-4ddd-910a-65f9e08b84d4 Timeout:15 Limit:0 Debug:false}"}
    {"time":"2025-01-08T13:38:47.1847382+08:00","level":"INFO","msg":"algorithm grpc client cc, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:8094acdb-8135-4c95-be4d-e828b3b1775d SK:8cd1818a-df64-4ddd-910a-65f9e08b84d4 Timeout:15 Limit:0 Debug:false}"}
    {"time":"2025-01-08T13:38:47.1847382+08:00","level":"INFO","msg":"grpc create conn,serviceName: algorithm config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:project ProjectId:default AK:8094acdb-8135-4c95-be4d-e828b3b1775d SK:8cd1818a-df64-4ddd-910a-65f9e08b84d4 Timeout:15 Limit:100 Debug:false}"}
    WARN msg=[http resolver]Zero endpoint found,refused to write,set: algorithm ins: []
    {"time":"2025-01-08T13:38:47.9105724+08:00","level":"INFO","msg":"连接driver: 配置={Host:127.0.0.1 Port:9224 Health:{RequestTime:10s Retry:3} Stream:{Heartbeat:30s} WaitTime:5s Timeout:10m0s Limit:100}","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:47.9105724+08:00","level":"INFO","msg":"健康检查: 启动","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"运行驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:47.9105724+08:00","level":"INFO","msg":"httpProxy: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:47.9105724+08:00","level":"INFO","msg":"schema: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:47.9105724+08:00","level":"INFO","msg":"start: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:47.9105724+08:00","level":"INFO","msg":"执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:47.9105724+08:00","level":"INFO","msg":"写数据点: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:47.9105724+08:00","level":"INFO","msg":"批量执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:47.9105724+08:00","level":"INFO","msg":"调试: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:47.91157+08:00","level":"ERROR","msg":"健康检查: 健康检查第 1 次错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"健康检查","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing: dial tcp 127.0.0.1:9224: connectex: No connection could be made because the target machine actively refused it.""}
    {"time":"2025-01-08T13:38:47.91157+08:00","level":"ERROR","msg":"httpProxy: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing: dial tcp 127.0.0.1:9224: connectex: No connection could be made because the target machine actively refused it.""}
    {"time":"2025-01-08T13:38:47.91157+08:00","level":"ERROR","msg":"schema: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing: dial tcp 127.0.0.1:9224: connectex: No connection could be made because the target machine actively refused it.""}
    {"time":"2025-01-08T13:38:47.91157+08:00","level":"ERROR","msg":"start: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing: dial tcp 127.0.0.1:9224: connectex: No connection could be made because the target machine actively refused it.""}
    {"time":"2025-01-08T13:38:47.91157+08:00","level":"ERROR","msg":"执行指令: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing: dial tcp 127.0.0.1:9224: connectex: No connection could be made because the target machine actively refused it.""}
    {"time":"2025-01-08T13:38:47.91157+08:00","level":"ERROR","msg":"写数据点: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing: dial tcp 127.0.0.1:9224: connectex: No connection could be made because the target machine actively refused it.""}
    {"time":"2025-01-08T13:38:47.91157+08:00","level":"ERROR","msg":"批量执行指令: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing: dial tcp 127.0.0.1:9224: connectex: No connection could be made because the target machine actively refused it.""}
    {"time":"2025-01-08T13:38:47.91157+08:00","level":"ERROR","msg":"调试: stream创建错误","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2","detail":"rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing: dial tcp 127.0.0.1:9224: connectex: No connection could be made because the target machine actively refused it.""}
    WARN msg=[resolver] Zero endpoint found,refused to write, instances: []
    {"time":"2025-01-08T13:38:52.9415175+08:00","level":"INFO","msg":"schema: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:52.9415175+08:00","level":"INFO","msg":"schema: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Schema","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:52.9417806+08:00","level":"INFO","msg":"httpProxy: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:52.9417806+08:00","level":"INFO","msg":"httpProxy: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"Http代理","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:52.9417806+08:00","level":"INFO","msg":"调试: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:52.9417806+08:00","level":"INFO","msg":"调试: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"调试","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:52.9417806+08:00","level":"INFO","msg":"执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:52.9417806+08:00","level":"INFO","msg":"执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:52.9417806+08:00","level":"INFO","msg":"写数据点: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:52.9417806+08:00","level":"INFO","msg":"写数据点: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"写数据点","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:52.9417806+08:00","level":"INFO","msg":"start: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:52.9417806+08:00","level":"INFO","msg":"start: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:52.94338+08:00","level":"INFO","msg":"批量执行指令: 启动stream","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:52.945881+08:00","level":"INFO","msg":"批量执行指令: stream连接成功","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"批量执行指令","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:54.2885059+08:00","level":"INFO","msg":"启动驱动","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:54.4780259+08:00","level":"INFO","msg":"表接口已注册: 设备表=HttpServer,请求路径=/http-server-driver/count,请求方式=[GET POST PUT]","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","table":"HttpServer","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:54.4780259+08:00","level":"INFO","msg":"表接口注册: 设备表=HttpServer,请求路径=/count,请求方式=[GET POST PUT]","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","table":"HttpServer","group":"67501da4a9045af51870e5f2"}
    {"time":"2025-01-08T13:38:57.4996287+08:00","level":"INFO","msg":"启动驱动: 驱动已启动, listening on :2886","logType":"syslog","service":"default-67501da4a9045af51870e5f2-http-server-driver","module":"启动驱动","projectId":"default","group":"67501da4a9045af51870e5f2"}
    yfyfzw
    不一定具有参考价值
    在 中回复了 yfyfzw 最后由 编辑
    @yfyfzw 发的是lib\pm2\logs 里面的 http-server 的日志是吧,服务器什么时候重启的
    yfyfzw
    大约在一点半左右吧,
    http-server驱动以及driver服务是什么版本
    重启服务器后,发现驱动有问题,大概多久重启的驱动
    yfyfzw
    既然PLC开发同事已经发现问题了,先解决吧,解决后也许都会好用,暂时不具备实验条件,工况比较复杂
    好的,httpserver驱动目前从日志看,从重启服务器到最后大概有 2 分钟的时间,这个时候可能平台其它服务还没启动完,所以一直在重启,可能再等个一两分钟就恢复了
    ab plc驱动的问题我们这边开发同事需要看看驱动代码,有进展后跟你说
    yfyfzw
    问题是否已经解决?
    我们这边已经升级了,将ab plc升级到最新版本就可以了
