西门子S7驱动报错
2023/12/01 14:56:18 版本: v4.0.15
{"time":"2023-12-01T14:56:18.0850342+08:00","level":"INFO","msg":"MQTT 已连接"}
{"time":"2023-12-01T14:56:18.0850342+08:00","level":"INFO","msg":"连接driver: {Host:127.0.0.1 Port:9224 Health:{RequestTime:10 Retry:3} WaitTime:5}"}
{"time":"2023-12-01T14:56:18.0855953+08:00","level":"INFO","msg":"健康检查启动"}
{"time":"2023-12-01T14:56:18.0855953+08:00","level":"INFO","msg":"启动驱动batchRun stream","logType":"syslog","service":"default-656701b24320ba263e53a856-siemens-s7","module":"批量执行指令","projectId":"default"}
{"time":"2023-12-01T14:56:18.0855953+08:00","level":"INFO","msg":"启动驱动http proxy stream","logType":"syslog","service":"default-656701b24320ba263e53a856-siemens-s7","module":"Http代理","projectId":"default"}
{"time":"2023-12-01T14:56:18.0866114+08:00","level":"INFO","msg":"启动驱动writeTag stream","logType":"syslog","service":"default-656701b24320ba263e53a856-siemens-s7","module":"写数据点","projectId":"default"}
{"time":"2023-12-01T14:56:18.0866114+08:00","level":"INFO","msg":"启动驱动schema stream","logType":"syslog","service":"default-656701b24320ba263e53a856-siemens-s7","module":"Schema","projectId":"default"}
{"time":"2023-12-01T14:56:18.0866114+08:00","level":"INFO","msg":"启动驱动run stream","logType":"syslog","service":"default-656701b24320ba263e53a856-siemens-s7","module":"执行指令","projectId":"default"}
{"time":"2023-12-01T14:56:18.0866114+08:00","level":"INFO","msg":"启动驱动start stream","logType":"syslog","service":"default-656701b24320ba263e53a856-siemens-s7","module":"启动驱动","projectId":"default"}
{"time":"2023-12-01T14:56:18.0866114+08:00","level":"INFO","msg":"启动驱动debug stream","logType":"syslog","service":"default-656701b24320ba263e53a856-siemens-s7","module":"调试","projectId":"default"}
{"time":"2023-12-01T14:56:23.0898006+08:00","level":"ERROR","msg":"执行 Start, 错误为响应不成功,试用版点数为20,超出点数","logType":"syslog","service":"default-656701b24320ba263e53a856-siemens-s7","module":"健康检查","projectId":"default"}
