时序数据库查询错误
日志查询
显示时间戳
时间
行数
100
自动刷新
日志详情
fcrypto/tls.(*Conn).readFromUntil(0xc000131180, 0x2568340, 0xc0007ec068, 0x5, 0xc0007ec068, 0x1541840)
0 /usr/local/go/src/crypto/tls/conn.go:802 +0xec
Icrypto/tls.(*Conn).readRecordOrCCS(0xc000131180, 0x0, 0x0, 0xc0027d8dd0)
1 /usr/local/go/src/crypto/tls/conn.go:609 +0x124
#crypto/tls.(Conn).readRecord(...)
/usr/local/go/src/crypto/tls/conn.go:577
Scrypto/tls.(*Conn).Read(0xc000131180, 0xc016374000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
2 /usr/local/go/src/crypto/tls/conn.go:1255 +0x161
onet/http.(*persistConn).Read(0xc00022ed80, 0xc016374000, 0x1000, 0x1000, 0xc0027d8ed8, 0x45c720, 0xc0027d8ed8)
4 /usr/local/go/src/net/http/transport.go:1758 +0x75
#bufio.(*Reader).fill(0xc01631b380)
- /usr/local/go/src/bufio/bufio.go:100 +0x103
Jbufio.(*Reader).Peek(0xc01631b380, 0x1, 0x2, 0x0, 0x0, 0xc01618f200, 0x0)
, /usr/local/go/src/bufio/bufio.go:138 +0x4f
/net/http.(persistConn).readLoop(0xc00022ed80)
5 /usr/local/go/src/net/http/transport.go:1911 +0x1d6
created by net/http.(*Transport).dialConn
5 /usr/local/go/src/net/http/transport.go:1580 +0xb0d
goroutine 1556 [select]:
]net/http.setRequestCancel.func3(0x0, 0xc002367440, 0xc000eab4a0, 0xc00b72c878, 0xc00009b9e0)
0 /usr/local/go/src/net/http/client.go:321 +0xcf
%created by net/http.setRequestCancel
1 /usr/local/go/src/net/http/client.go:320 +0x24b
�ts=2026-01-21T04:08:04.006818Z lvl=info msg="InfluxDB starting" log_id=10ZgeOeW000 version=1.8.10 branch=1.8 commit=688e697c51fd
its=2026-01-21T04:08:04.006850Z lvl=info msg="Go runtime" log_id=10ZgeOeW000 version=go1.13.8 maxprocs=12
zts=2026-01-21T04:08:04.020099Z lvl=info msg="Using data dir" log_id=10ZgeOeW000 service=store path=/var/lib/influxdb/data
�ts=2026-01-21T04:08:04.020154Z lvl=info msg="Compaction settings" log_id=10ZgeOeW000 service=store max_concurrent_compactions=6 throughput_bytes_per_second=50331648 throughput_bytes_per_second_burst=50331648
�ts=2026-01-21T04:08:04.020166Z lvl=info msg="Open store (start)" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open op_event=start
�ts=2026-01-21T04:08:04.034575Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/153/000000001-000000001.tsm id=0 duration=0.956ms
�ts=2026-01-21T04:08:04.039199Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/171 duration=13.495ms
�ts=2026-01-21T04:08:04.055619Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/152/000000013-000000002.tsm id=0 duration=14.055ms
�ts=2026-01-21T04:08:04.067781Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/150/000000017-000000002.tsm id=0 duration=11.237ms
�ts=2026-01-21T04:08:04.068607Z lvl=info msg="Reading file" log_id=10ZgeOeW000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/default/autogen/159/_00001.wal size=10492523
�ts=2026-01-21T04:08:04.047141Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/167/000000001-000000001.tsm id=0 duration=4.866ms
�ts=2026-01-21T04:08:04.082647Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/151/000000016-000000003.tsm id=0 duration=43.221ms
�ts=2026-01-21T04:08:04.085514Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/154/000000003-000000002.tsm id=0 duration=48.510ms
�ts=2026-01-21T04:08:04.088544Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/22/000000029-000000002.tsm id=0 duration=40.555ms
�ts=2026-01-21T04:08:04.124605Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/2/000000091-000000002.tsm id=0 duration=45.815ms
�ts=2026-01-21T04:08:04.128684Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/101/000000051-000000002.tsm id=0 duration=79.678ms
�ts=2026-01-21T04:08:04.134553Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/167 duration=92.909ms
�ts=2026-01-21T04:08:04.137430Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/14/000000042-000000002.tsm id=0 duration=1.616ms
�ts=2026-01-21T04:08:04.159416Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/148/000000017-000000002.tsm id=0 duration=122.647ms
�ts=2026-01-21T04:08:04.167518Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/161/000000001-000000001.tsm id=0 duration=130.554ms
�ts=2026-01-21T04:08:04.301923Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/154 duration=278.270ms
�ts=2026-01-21T04:08:04.307995Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/109/000000015-000000002.tsm id=0 duration=5.403ms
�ts=2026-01-21T04:08:04.352162Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/22 duration=310.458ms
�ts=2026-01-21T04:08:04.352236Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/150 duration=319.195ms
�ts=2026-01-21T04:08:04.352508Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/14 duration=217.894ms
�ts=2026-01-21T04:08:04.353601Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/2 duration=301.614ms
�ts=2026-01-21T04:08:04.356161Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/12/000000007-000000002.tsm id=0 duration=0.563ms
�ts=2026-01-21T04:08:04.359652Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/13/000000054-000000002.tsm id=0 duration=5.505ms
�ts=2026-01-21T04:08:04.361045Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/125/000000025-000000003.tsm id=0 duration=7.932ms
�ts=2026-01-21T04:08:04.362146Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/117/000000020-000000002.tsm id=0 duration=9.304ms
�ts=2026-01-21T04:08:04.369001Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/101 duration=329.757ms
�ts=2026-01-21T04:08:04.369079Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/153 duration=344.526ms
�ts=2026-01-21T04:08:04.369082Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/148 duration=344.335ms
�ts=2026-01-21T04:08:04.394525Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/152 duration=370.829ms
�ts=2026-01-21T04:08:04.406523Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/161 duration=381.877ms
�ts=2026-01-21T04:08:04.406703Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/151 duration=364.633ms
�ts=2026-01-21T04:08:04.419399Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/157/000000001-000000001.tsm id=0 duration=26.424ms
�ts=2026-01-21T04:08:04.441352Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/149/000000021-000000002.tsm id=0 duration=24.842ms
�ts=2026-01-21T04:08:04.444536Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/12 duration=92.277ms
�ts=2026-01-21T04:08:04.446552Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/149/000000022-000000001.tsm id=1 duration=31.498ms
�ts=2026-01-21T04:08:04.450811Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/133/000000024-000000003.tsm id=0 duration=67.302ms
�ts=2026-01-21T04:08:04.460217Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/156/000000001-000000001.tsm id=0 duration=68.538ms
�ts=2026-01-21T04:08:04.460803Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/141/000000025-000000002.tsm id=0 duration=12.187ms
�ts=2026-01-21T04:08:04.482003Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/158/000000001-000000001.tsm id=0 duration=59.120ms
�ts=2026-01-21T04:08:04.512310Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/13 duration=158.675ms
�ts=2026-01-21T04:08:04.528871Z lvl=info msg="Reading file" log_id=10ZgeOeW000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/default/autogen/163/_00001.wal size=10522280
�ts=2026-01-21T04:08:04.657427Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/16/000000031-000000002.tsm id=0 duration=1.265ms
�ts=2026-01-21T04:08:04.838100Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/16 duration=325.737ms
�ts=2026-01-21T04:08:04.886390Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/109 duration=584.407ms
�ts=2026-01-21T04:08:04.962608Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/117 duration=610.387ms
�ts=2026-01-21T04:08:04.965622Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/160/000000001-000000001.tsm id=0 duration=6.232ms
�ts=2026-01-21T04:08:04.965743Z lvl=info msg="Reading file" log_id=10ZgeOeW000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/default/autogen/160/_00001.wal size=9214353
�ts=2026-01-21T04:08:04.966667Z lvl=info msg="Reading file" log_id=10ZgeOeW000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/default/autogen/162/_00001.wal size=10584142
�ts=2026-01-21T04:08:04.984834Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/170/000000001-000000001.tsm id=0 duration=0.085ms
�ts=2026-01-21T04:08:05.097531Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/156 duration=728.422ms
�ts=2026-01-21T04:08:05.097980Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/168/000000001-000000001.tsm id=0 duration=0.069ms
�ts=2026-01-21T04:08:05.128509Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/141 duration=721.764ms
�ts=2026-01-21T04:08:05.129366Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/169/000000001-000000001.tsm id=0 duration=0.064ms
�ts=2026-01-21T04:08:05.138146Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/170 duration=175.481ms
�ts=2026-01-21T04:08:05.146557Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/17/000000029-000000002.tsm id=0 duration=7.280ms
�ts=2026-01-21T04:08:05.162070Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/149 duration=755.478ms
�ts=2026-01-21T04:08:05.164395Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/20/000000030-000000002.tsm id=0 duration=1.423ms
�ts=2026-01-21T04:08:05.203901Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/125 duration=851.364ms
�ts=2026-01-21T04:08:05.205816Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/21/000000027-000000002.tsm id=0 duration=0.952ms
�ts=2026-01-21T04:08:05.207518Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/133 duration=838.464ms
�ts=2026-01-21T04:08:05.209242Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/34/000000030-000000002.tsm id=0 duration=0.879ms
�ts=2026-01-21T04:08:05.212304Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/169 duration=83.332ms
�ts=2026-01-21T04:08:05.223385Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/27/000000031-000000002.tsm id=0 duration=10.223ms
�ts=2026-01-21T04:08:05.247544Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/168 duration=149.947ms
�ts=2026-01-21T04:08:05.257623Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/28/000000030-000000002.tsm id=0 duration=9.169ms
�ts=2026-01-21T04:08:05.322194Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/157 duration=953.081ms
�ts=2026-01-21T04:08:05.325190Z lvl=info msg="Opened file" log_id=10ZgeOeW000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/default/autogen/29/000000030-000000002.tsm id=0 duration=1.132ms
�ts=2026-01-21T04:08:05.376154Z lvl=info msg="Opened shard" log_id=10ZgeOeW000 service=store trace_id=10ZgeOi0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/default/autogen/158 duration=981.577ms
�ts=2026-01-21T04:08:05.377059Z lvl=info msg="Reading file" log_id=10ZgeOeW000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/default/autogen/172/_00001.wal size=1449992 -
检查容器
检查
树状形式文档形式
"Id":"99cbca97239ae9d901e0fe7ef4f47f4356c8d69ec0899b81765e071f39231319",
"Created":"2025-04-10T05:23:25.055298757Z",
"Path":"/entrypoint.sh",
"Args":["influxd"],
"State":{
"Status":"restarting",
"Running":true,
"Paused":false,
"Restarting":true,
"OOMKilled":false,
"Dead":false,
"Pid":0,
"ExitCode":2,
"Error":"",
"StartedAt":"2026-01-21T06:07:44.066619948Z",
"FinishedAt":"2026-01-21T06:07:52.837423483Z"
"Image":"sha256:d918bc1feeef58203db58b5c00f0729fece29cbbb82b0381c1e8253c702c6737",
"ResolvConfPath":"/home/app/airiot/docker/containers/99cbca97239ae9d901e0fe7ef4f47f4356c8d69ec0899b81765e071f39231319/resolv.conf",
"HostnamePath":"/home/app/airiot/docker/containers/99cbca97239ae9d901e0fe7ef4f47f4356c8d69ec0899b81765e071f39231319/hostname",
"HostsPath":"/home/app/airiot/docker/containers/99cbca97239ae9d901e0fe7ef4f47f4356c8d69ec0899b81765e071f39231319/hosts",
"LogPath":"/home/app/airiot/docker/containers/99cbca97239ae9d901e0fe7ef4f47f4356c8d69ec0899b81765e071f39231319/99cbca97239ae9d901e0fe7ef4f47f4356c8d69ec0899b81765e071f39231319-json.log",
"Name":"/influx",
"RestartCount":422,
"Driver":"overlay2",
"Platform":"linux",
"MountLabel":"",
"ProcessLabel":"",
"AppArmorProfile":"",
"ExecIDs":null,
"HostConfig":{
"Binds":["/etc/localtime:/etc/localtime:ro",
"/home/app/airiot/influxdb.conf:/etc/influxdb/influxdb.conf:rw",
"/home/app/airiot/db/influxdb:/var/lib/influxdb:rw"],
"ContainerIDFile":"",
"LogConfig":{
"Type":"json-file",
"Config":{
"max-file":"1",
"max-size":"100m"}
"NetworkMode":"app_backend",
"PortBindings":{}, "RestartPolicy":{ "Name":"always", "MaximumRetryCount":0 }, "AutoRemove":false, "VolumeDriver":"", "VolumesFrom":null, "ConsoleSize":[0, 0], "CapAdd":null, "CapDrop":null, "CgroupnsMode":"", "Dns":[], "DnsOptions":[], "DnsSearch":[], "ExtraHosts":null, "GroupAdd":null, "IpcMode":"private", "Cgroup":"", "Links":null, "OomScoreAdj":0, "PidMode":"", "Privileged":false, "PublishAllPorts":false, "ReadonlyRootfs":false, "SecurityOpt":null, "UTSMode":"", "UsernsMode":"", "ShmSize":67108864, "Runtime":"runc", "Isolation":"", "CpuShares":0, "Memory":0, "NanoCpus":0, "CgroupParent":"", "BlkioWeight":0, "BlkioWeightDevice":null, "BlkioDeviceReadBps":null, "BlkioDeviceWriteBps":null, "BlkioDeviceReadIOps":null, "BlkioDeviceWriteIOps":null, "CpuPeriod":0, "CpuQuota":0, "CpuRealtimePeriod":0, "CpuRealtimeRuntime":0, "CpusetCpus":"", "CpusetMems":"", "Devices":null, "DeviceCgroupRules":null, "DeviceRequests":null, "MemoryReservation":0, "MemorySwap":0, "MemorySwappiness":null, "OomKillDisable":false, "PidsLimit":null, "Ulimits":[{ "Name":"nofile", "Hard":30720, "Soft":10240 }, { "Name":"nproc", "Hard":40960, "Soft":40960}], "CpuCount":0, "CpuPercent":0, "IOMaximumIOps":0, "IOMaximumBandwidth":0, "MaskedPaths":["/proc/asound", "/proc/acpi", "/proc/kcore", "/proc/keys", "/proc/latency_stats", "/proc/timer_list", "/proc/timer_stats", "/proc/sched_debug", "/proc/scsi", "/sys/firmware"], "ReadonlyPaths":["/proc/bus", "/proc/fs", "/proc/irq", "/proc/sys", "/proc/sysrq-trigger"] }, "GraphDriver":{ "Data":{ "LowerDir":"/home/app/airiot/docker/overlay2/159775c2d5ffbcc4febd19b20b8b1b96a3d56654beae1d3dd51eeb0b946ed96d-init/diff:/home/app/airiot/docker/overlay2/8f6721c6ed4c947f1de0c10f5bd9c822ace567b622f99c07e02c0c7c1a8855a3/diff:/home/app/airiot/docker/overlay2/ac27986bc9057820c03319680863f4a39df80a7efe0fbdb4c95e80860ea0a37a/diff:/home/app/airiot/docker/overlay2/53d2d0ada0bcfc3aed7218947a1b6d0bd54240257a29f8359d8055e0c040ae3f/diff:/home/app/airiot/docker/overlay2/08774460929f1109d6a650a655a31665a8550dc7e294a9e580012d23aeffa335/diff:/home/app/airiot/docker/overlay2/ac2a258a2658a00967bf11e588fce74ef9467fd152bde1b484f7d0224516eb58/diff:/home/app/airiot/docker/overlay2/5a33383a064853bf3e1d5e8a6ae496101fa56f84ae35a4a260e155b66756f7a8/diff:/home/app/airiot/docker/overlay2/20042e3a01fd5d0fdbe7101258b9d8be0096a664b4c7c3f611e5016bd1dc8609/diff", "MergedDir":"/home/app/airiot/docker/overlay2/159775c2d5ffbcc4febd19b20b8b1b96a3d56654beae1d3dd51eeb0b946ed96d/merged", "UpperDir":"/home/app/airiot/docker/overlay2/159775c2d5ffbcc4febd19b20b8b1b96a3d56654beae1d3dd51eeb0b946ed96d/diff", "WorkDir":"/home/app/airiot/docker/overlay2/159775c2d5ffbcc4febd19b20b8b1b96a3d56654beae1d3dd51eeb0b946ed96d/work" }, "Name":"overlay2" }, "Mounts":[{ "Type":"bind", "Source":"/home/app/airiot/influxdb.conf", "Destination":"/etc/influxdb/influxdb.conf", "Mode":"rw", "RW":true, "Propagation":"rprivate" }, { "Type":"bind", "Source":"/etc/localtime", "Destination":"/etc/localtime", "Mode":"ro", "RW":false, "Propagation":"rprivate" }, { "Type":"bind", "Source":"/home/app/airiot/db/influxdb", "Destination":"/var/lib/influxdb", "Mode":"rw", "RW":true, "Propagation":"rprivate"}], "Config":{ "Hostname":"99cbca97239a", "Domainname":"", "User":"", "AttachStdin":false, "AttachStdout":true, "AttachStderr":true, "ExposedPorts":{ "8086/tcp":{ } }, "Tty":false, "OpenStdin":false, "StdinOnce":false, "Env":["INFLUXDB_DB=tsdb", "INFLUXDB_HTTP_AUTH_ENABLED=true", "INFLUXDB_ADMIN_USER=admin", "INFLUXDB_ADMIN_PASSWORD=qVPWSP9zxv", "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin", "INFLUXDB_VERSION=1.8.10"], "Cmd":["influxd"], "Image":"influxdb:1.8.10-alpine", "Volumes":{ "/etc/influxdb/influxdb.conf":{ }, "/etc/localtime":{ }, "/var/lib/influxdb":{ } }, "WorkingDir":"", "Entrypoint":["/entrypoint.sh"], "OnBuild":null, "Labels":{ "com.docker.compose.config-hash":"32b091278134a0c5c240f125023bf28f4356ea366f98c5c6e0bedc444a85d5d0", "com.docker.compose.container-number":"1", "com.docker.compose.depends_on":"", "com.docker.compose.image":"sha256:d918bc1feeef58203db58b5c00f0729fece29cbbb82b0381c1e8253c702c6737", "com.docker.compose.oneoff":"False", "com.docker.compose.project":"app", "com.docker.compose.project.config_files":"/home/app/docker-compose.yml", "com.docker.compose.project.working_dir":"/home/app", "com.docker.compose.service":"influx", "com.docker.compose.version":"2.2.2"} }, "NetworkSettings":{ "Bridge":"", "SandboxID":"2789b77ac50a32b6c4b7817754c3cd4470bcc15e43faf699baf8b43215a10c74", "SandboxKey":"/var/run/docker/netns/2789b77ac50a", "Ports":{ }, "HairpinMode":false, "LinkLocalIPv6Address":"", "LinkLocalIPv6PrefixLen":0, "SecondaryIPAddresses":null, "SecondaryIPv6Addresses":null, "EndpointID":"", "Gateway":"", "GlobalIPv6Address":"", "GlobalIPv6PrefixLen":0, "IPAddress":"", "IPPrefixLen":0, "IPv6Gateway":"", "MacAddress":"", "Networks":{ "app_backend":{ "IPAMConfig":null, "Links":null, "Aliases":["influx", "influx", "99cbca97239a"], "MacAddress":"", "DriverOpts":null, "NetworkID":"94c48086ea04993fe09fd01973b0dc02d13f8b8df0f27ec6cdae175eb847822c", "EndpointID":"", "Gateway":"", "IPAddress":"", "IPPrefixLen":0, "IPv6Gateway":"", "GlobalIPv6Address":"", "GlobalIPv6PrefixLen":0, "DNSNames":null }, "operation_backend":{ "IPAMConfig":null, "Links":null, "Aliases":["influx", "influx", "99cbca97239a"], "MacAddress":"", "DriverOpts":null, "NetworkID":"476c45fbca168af20dc819dacaaefada42858ab16fad177450a9ad5b85f0d4e4", "EndpointID":"", "Gateway":"", "IPAddress":"", "IPPrefixLen":0, "IPv6Gateway":"", "GlobalIPv6Address":"", "GlobalIPv6PrefixLen":0, "DNSNames":null}}}} -
发一下安装目录下的docker-compose.yml文件
可以通过这个在线传输上传 https://wormhole.app/ -
服务器root 密码进不去了,还有没有别的办法?
部署文件已经上传
时序数据库查询错误
Post "http://influx:8086/query?db=default¶ms=null&q=select++mean("D675")+from+"A油田抽油机"++where+id+%3D+'242'++++++and+time+>+'2026-01-22T00%3A51%3A00.000Z'+and+time+<%3D+'2026-01-22T00%3A51%3A38.676Z'+++order+by+time+asc++%3B": dial tcp 172.19.0.47:8086: connect: connection refused
不行,还是那样
