  3. python SDK 数据接入驱动开发问题
  • C 离线
    C 离线
    chenpengchao
    看一下这个示例代码,https://github.com/air-iot/sdk-python-examples/blob/master/driver/main.py
    hk
    按照教程打包驱动,离线上传驱动确定后,没有任何提示信息,搜索也搜索不到。
    日志没有任何信息。
    .tar包文件内容:
    jt808-driver.tar.gz内容:
    请帮忙看下是为什么不能上传离线驱动。
    hk
    @chenpengchao
  • C 离线
    C 离线
    chenpengchao
    发一下 service.yml 的内容
    hk
    驱动已成功上传,但是运行报错
    在打包docker后,在本地测试运行没有报错
    hk
    SDK中的 startup.py,没有看到--groupId参数的设置,是SDK版本不同么?
  • C 离线
    C 离线
    chenpengchao
    这个是后来添加的参数,把 sdk 升级到 v4.0.6. https://github.com/air-iot/sdk-python-examples/releases
    hk
    请问下,config.yml文件中的两个host地址具体应该如何填写?
    填平台域名,外部无法连接,填127.0.0.1后,驱动启动时连接mqtt_data_sender报错
    hk
    ]2025-07-04 10:23:46,244 INFO --- [ startup]: 启动驱动: jt808_driver_tcp_106
    Q2025-07-04 10:23:46,245 INFO --- [ launcher]: connect to data sender
    2025-07-04 10:23:46,245 INFO --- [ mqtt_data_sender]: start connect to mqtt server, MqttConfig(scheme=mqtt, host=127.0.0.1, port=1883, username=admin, password=4P1jILKAq5, skip_verify=False, version=4, keepalive=60, reconnect_interval=30, connect_timeout=15, publish_timeout=5)
    ]2025-07-04 10:23:46,248 ERROR --- [ base_events]: Task exception was never retrieved
    �future: <Task finished name='Task-1' coro=<DriverLauncher.start() done, defined at /usr/local/lib/python3.10/site-packages/airiot_python_sdk/driver/launcher.py:93> exception=ConnectionRefusedError(111, 'Connection refused')>
    #Traceback (most recent call last):
    j File "/usr/local/lib/python3.10/site-packages/airiot_python_sdk/driver/launcher.py", line 101, in start
    ! self.__connect_data_sender()
    z File "/usr/local/lib/python3.10/site-packages/airiot_python_sdk/driver/launcher.py", line 504, in __connect_data_sender
     self.data_sender.start()
    y File "/usr/local/lib/python3.10/site-packages/airiot_python_sdk/driver/service/mqtt_data_sender.py", line 73, in start
    g self.client.connect(host=self.config.host, port=self.config.port, keepalive=self.config.keepalive)
    [ File "/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py", line 914, in connect
     return self.reconnect()
    ^ File "/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py", line 1044, in reconnect
    , sock = self._create_socket_connection()
    n File "/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py", line 3685, in _create_socket_connection
    ` return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
    M File "/usr/local/lib/python3.10/socket.py", line 857, in create_connection
     raise err
    M File "/usr/local/lib/python3.10/socket.py", line 845, in create_connection
     sock.connect(sa)
    7ConnectionRefusedError: [Errno 111] Connection refused
    hk
    @chenpengchao
    hk
    已解决,暂时不用看了
    hk
    想问下自己开发的驱动,接收到的图片如何放到平台媒体库?@chenpengchao
    什么语言的》,?
    hk
    python的。。。
    python sdk 现在暂时没有这个接口
    hk
    python sdk执行平台下发指令报错:
    w2025-08-08 13:44:42,740 INFO --- [ launcher]: receive run request: 68958eca4d9ec31a8ac1c6de, result = None
    s File "/usr/local/lib/python3.10/site-packages/airiot_python_sdk/driver/launcher.py", line 313, in run_stream
    D await call.write(RunResult(request.request, r.encode("utf-8")))
    WTypeError: _AddInitMethod.<locals>.init() takes 1 positional argument but 3 were given
    __run_stream__接口中调用RunResult
    这个问题该如何解决?
    这个明天开发回复的话再看吧
  • C 离线
    C 离线
    chenpengchao
    试试 v4.0.8 版本,这个版本也增加了媒体库的接口
    hk
    问一下媒体库接口有文档可以参考下么?
    可以访问ip:31000看一下swagger里面的接口
