网络通信的数据怎么清理掉
@技术支持fx 没有备份,更没有周期备份```
time=2025-04-16T14:47:15.767+08:00 level=INFO msg="algorithm http client createConn, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:0 Debug:false Service:{Expire:30s}}"
time=2025-04-16T14:47:15.767+08:00 level=INFO msg="http create conn,serviceName: algorithm config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:0 Debug:false Service:{Expire:30s}}"
time=2025-04-16T14:47:15.837+08:00 level=INFO msg="algorithm grpc client cc, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:0 Debug:false Service:{Expire:30s}}"
time=2025-04-16T14:47:15.837+08:00 level=INFO msg="grpc create conn,serviceName: algorithm config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:100 Debug:false Service:{Expire:30s}}"
time=2025-04-16T14:47:16.203+08:00 level=INFO msg="core grpc client cc, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:0 Debug:false Service:{Expire:30s}}"
time=2025-04-16T14:47:16.203+08:00 level=INFO msg="grpc create conn,serviceName: core config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:100 Debug:false Service:{Expire:30s}}"
time=2025-04-16T14:47:16.233+08:00 level=INFO msg="MQTT 已经连接" logType=syslog service=tsdb-backup
time=2025-04-16T14:47:16.291+08:00 level=INFO msg="spm grpc client cc, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:0 Debug:false Service:{Expire:30s}}"
time=2025-04-16T14:47:16.291+08:00 level=INFO msg="grpc create conn,serviceName: spm config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:100 Debug:false Service:{Expire:30s}}"
time=2025-04-16T14:48:16.561+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T14:49:16.576+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T14:50:16.585+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T14:51:16.590+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T14:52:16.594+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T14:53:16.602+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T14:54:16.610+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T14:55:16.611+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T14:56:16.615+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T14:57:16.617+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T14:58:16.620+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T14:59:16.622+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:00:16.624+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:01:16.625+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:02:16.627+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:03:16.638+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:04:16.648+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:05:16.658+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:06:16.662+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:07:16.664+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:08:16.665+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:09:16.674+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:10:16.680+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:11:16.692+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:12:16.697+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:13:16.708+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:14:16.712+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:15:16.716+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:16:16.717+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:17:16.725+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:18:16.728+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:19:16.739+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:20:16.742+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:21:16.750+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:22:16.755+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:23:16.758+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:24:16.764+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:25:16.766+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:26:16.772+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:27:16.781+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:28:16.784+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:29:16.792+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:30:16.797+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:31:16.804+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:32:16.811+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:33:16.813+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:34:16.818+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:35:16.828+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:36:16.836+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:37:16.839+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:38:16.845+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:39:16.856+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:40:16.857+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:41:16.864+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:42:16.872+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:43:16.879+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:44:16.881+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:45:16.888+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:46:16.890+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:47:16.896+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:48:16.900+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:49:16.917+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:50:16.919+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:51:16.923+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:52:16.925+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:53:16.930+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:54:16.933+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:55:16.938+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:56:16.943+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:57:16.946+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:58:16.949+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T15:59:16.954+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:00:16.956+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:01:16.965+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:02:16.970+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:03:16.976+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:04:16.982+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:05:16.988+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:06:16.991+08:00 level=INFO msg="start check the registered service list."2025/04/16 16:06:31 [31;1m/go/pkg/mod/git.airiot.tech/core/service.git/v4@v4.4.104/gormdb/gorm.go:174 [35;1mERROR: relation "muyuauto.tsdb_backup" does not exist (SQLSTATE 42P01)
[0m[33m[39.814ms] [34;1m[rows:0][0m SELECT count(*) FROM "muyuauto"."tsdb_backup" WHERE "type" = 'dump' AND "status" = 'success'2025/04/16 16:06:31 [31;1m/go/pkg/mod/git.airiot.tech/core/service.git/v4@v4.4.104/gormdb/gorm.go:61 [35;1mERROR: relation "muyuauto.tsdb_backup_remote" does not exist (SQLSTATE 42P01)
[0m[33m[33.031ms] [34;1m[rows:0][0m SELECT * FROM "muyuauto"."tsdb_backup_remote" WHERE id='ftp'
time=2025-04-16T16:07:16.995+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:08:16.999+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:09:17.006+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:10:17.012+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:11:17.019+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:12:17.026+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:13:17.040+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:14:17.043+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:15:17.055+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:16:17.060+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:17:17.065+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:18:17.066+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:19:17.079+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:20:17.082+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:21:17.087+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:22:17.094+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:23:17.097+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:24:17.098+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:25:17.101+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:26:17.106+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:27:17.115+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:28:17.118+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:29:17.125+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:30:17.134+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:31:17.140+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:32:17.141+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:33:17.153+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:34:17.155+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:35:17.162+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:36:17.170+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:37:17.176+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:38:17.183+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:39:17.184+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:40:17.188+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:41:17.191+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:42:17.195+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:43:17.198+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:44:17.199+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:45:17.199+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:46:17.201+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:47:17.212+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:48:17.214+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:49:17.219+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:50:17.230+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:51:17.235+08:00 level=INFO msg="start check the registered service list."
time=2025-04-16T16:52:17.238+08:00 level=INFO msg="start check the registered service list." -
@技术支持fx
time=2025-04-17T08:08:13.394+08:00 level=INFO msg="algorithm http client createConn, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:0 Debug:false Service:{Expire:30s}}"
time=2025-04-17T08:08:13.394+08:00 level=INFO msg="http create conn,serviceName: algorithm config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:0 Debug:false Service:{Expire:30s}}"
time=2025-04-17T08:08:13.464+08:00 level=INFO msg="algorithm grpc client cc, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:0 Debug:false Service:{Expire:30s}}"
time=2025-04-17T08:08:13.464+08:00 level=INFO msg="grpc create conn,serviceName: algorithm config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:100 Debug:false Service:{Expire:30s}}"
time=2025-04-17T08:08:13.889+08:00 level=INFO msg="core grpc client cc, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:0 Debug:false Service:{Expire:30s}}"
time=2025-04-17T08:08:13.889+08:00 level=INFO msg="grpc create conn,serviceName: core config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:100 Debug:false Service:{Expire:30s}}"
time=2025-04-17T08:08:13.914+08:00 level=INFO msg="MQTT 已经连接" logType=syslog service=tsdb-backup
time=2025-04-17T08:08:13.986+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:08:23.889213145 +0800 CST m=+10.799393410 [9.902532976s]).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:08:13.986+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.18.0.33:9223"
time=2025-04-17T08:08:13.986+08:00 level=INFO msg="spm grpc client cc, {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:0 Debug:false Service:{Expire:30s}}"
time=2025-04-17T08:08:13.986+08:00 level=INFO msg="grpc create conn,serviceName: spm config: {Gateway: EtcdConfig:/airiot/config/pro.json Metadata:map[env:local] Services:map[] Type:tenant ProjectId: AK:9EF6D55C-74A9-4B08-B-D7-0609-BBAF-B93D SK:A5C6C5E6-065F-4B46-B-37-414B-F089-9E2E Timeout:60 Limit:100 Debug:false Service:{Expire:30s}}"
time=2025-04-17T08:08:14.129+08:00 level=DEBUG msg="client context: context.Background.WithValue(type transport.clientTransportKey, val <not Stringer>).WithDeadline(2025-04-17 08:09:14.12374648 +0800 CST m=+61.033926733 [59.994652862s]).WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:08:14.129+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.19.0.17:9222"
time=2025-04-17T08:08:14.161+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:08:23.889213145 +0800 CST m=+10.799393410 [9.72742934s]).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:08:14.161+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.19.0.17:9222"
time=2025-04-17T08:08:14.176+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:08:23.889213145 +0800 CST m=+10.799393410 [9.712416365s]).WithValue(type logger.projectKey, val muyuauto).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:08:14.176+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.18.0.33:9223"
time=2025-04-17T08:09:14.158+08:00 level=INFO msg="start check the registered service list."
time=2025-04-17T08:09:14.208+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:09:24.207953415 +0800 CST m=+71.118133699 [9.9999274s]).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:09:14.208+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.18.0.33:9223"
time=2025-04-17T08:09:14.208+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:09:24.207953415 +0800 CST m=+71.118133699 [9.999224567s]).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:09:14.208+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.19.0.17:9222"
time=2025-04-17T08:09:14.211+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:09:24.207953415 +0800 CST m=+71.118133699 [9.996329502s]).WithValue(type logger.projectKey, val muyuauto).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:09:14.211+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.18.0.33:9223"
time=2025-04-17T08:10:14.164+08:00 level=INFO msg="start check the registered service list."
time=2025-04-17T08:10:14.216+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:10:24.215950518 +0800 CST m=+131.126130792 [9.999930502s]).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:10:14.216+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.18.0.33:9223"
time=2025-04-17T08:10:14.245+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:10:24.215950518 +0800 CST m=+131.126130792 [9.970570593s]).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:10:14.245+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.19.0.17:9222"
time=2025-04-17T08:10:14.269+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:10:24.215950518 +0800 CST m=+131.126130792 [9.946227386s]).WithValue(type logger.projectKey, val muyuauto).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:10:14.269+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.18.0.33:9223"
time=2025-04-17T08:11:14.177+08:00 level=INFO msg="start check the registered service list."
time=2025-04-17T08:11:14.285+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:11:24.285055763 +0800 CST m=+191.195236029 [9.999911254s]).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:11:14.285+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.18.0.33:9223"
time=2025-04-17T08:11:14.290+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:11:24.285055763 +0800 CST m=+191.195236029 [9.994896304s]).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:11:14.290+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.19.0.17:9222"
time=2025-04-17T08:11:14.307+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:11:24.285055763 +0800 CST m=+191.195236029 [9.977693465s]).WithValue(type logger.projectKey, val muyuauto).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:11:14.307+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.18.0.33:9223"
time=2025-04-17T08:12:14.181+08:00 level=INFO msg="start check the registered service list."
time=2025-04-17T08:12:14.314+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:12:24.314000755 +0800 CST m=+251.224181060 [9.999871616s]).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:12:14.314+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.18.0.33:9223"
time=2025-04-17T08:12:14.316+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:12:24.314000755 +0800 CST m=+251.224181060 [9.997829684s]).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:12:14.316+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.19.0.17:9222"
time=2025-04-17T08:12:14.337+08:00 level=DEBUG msg="client context: context.Background.WithCancel.WithDeadline(2025-04-17 08:12:24.314000755 +0800 CST m=+251.224181060 [9.9770063s]).WithValue(type logger.projectKey, val muyuauto).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithValue(type transport.clientTransportKey, val <not Stringer>).WithCancel.WithValue(type selector.peerKey, val <not Stringer>).WithValue(type trace.traceContextKeyType, val <not Stringer>).WithValue(type metadata.mdOutgoingKey, val <not Stringer>).WithCancel.WithValue(type grpc.rpcInfoContextKey, val <not Stringer>) metadata map[env:local]"
time=2025-04-17T08:12:14.337+08:00 level=DEBUG msg="client metadata nodes, Scheme: grpc, Metadata: map[env:local], Address: 172.18.0.33:9223"
更新一下这三个服务
