  3. 连接AP PLC多维数组可以上数 但不显示设备在线状态
  • Y 在线
    Y 在线
    yfyfzw
    重启电脑,设备监控->驱动管理 把驱动都清空,数据管理也清空了,重新添加,报的以上错误,
    windows版本,所有服务,模块都是最新的,
    只是想在调试本上,实验环境,测试下监控摄像头的报警弹窗,
    有时间帮忙解决下,谢谢
  • guangdaG 离线
    guangdaG 离线
    guangda
    驱动调用错误:可以看下这个驱动在驱动管理里面的状态 截图下
  • Y 在线
    Y 在线
    yfyfzw
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:32.697000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:32.698000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:32.698000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:32.698000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:32.698000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:32.698000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:32.699000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:33.198000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:33.199000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:33.199000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:33.199000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:33.199000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:33.199000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:33.199000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:33.698000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:33.699000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:33.699000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:33.699000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:33.699000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:33.700000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:33.700000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:34.199000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:34.199000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:34.199000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:34.200000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:34.200000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:34.200000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:34.200000000+08:00"}
    run接收数据 {
    3 request: '98eda22d-4506-4d7b-88bd-f98e32acebd2',
     tableId: 'PLCAB',
    4 serialNo: '866a1b79-4d80-4fb7-b7a8-16ae3947b9b7',
    � command: <Buffer 7b 22 66 6f 72 6d 22 3a 5b 7b 22 61 72 72 61 79 56 61 6c 75 65 22 3a 6e 75 6c 6c 2c 22 69 66 52 65 70 65 61 74 22 3a 6e 75 6c 6c 2c 22 69 6f 77 61 79 ... 580 more bytes>
     ab run..
     Tag0 Tag {
    ( _events: [Object: null prototype] {},
     _eventsCount: 0,
     _maxListeners: undefined,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -14.9,
     controllerValue: null,
    . path: <Buffer 91 05 52 43 58 5f 52 00>,
     program: null,
     stage_write: true
     read_size: 1,
    ) error: { code: null, status: null },
    ) timestamp: 2024-01-18T02:08:34.211Z,
    2 instance: '8a0b8156cddea8c72f4d0e979a437c7c',
     keepAlive: 0
     [Symbol(kCapture)]: false
    run接收数据 {
    3 request: 'c64a5a6e-28f1-4c6d-ac79-a89a612a7418',
     tableId: 'PLCAB',
    4 serialNo: 'bb733ddf-5660-481f-aab8-fbe1e3a9c3c4',
    � command: <Buffer 7b 22 66 6f 72 6d 22 3a 5b 7b 22 61 72 72 61 79 56 61 6c 75 65 22 3a 6e 75 6c 6c 2c 22 69 66 52 65 70 65 61 74 22 3a 6e 75 6c 6c 2c 22 69 6f 77 61 79 ... 694 more bytes>
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -16.3,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:08:34.273Z,
     keepAlive: 0
    run接收数据 {
    3 request: '7bff6a23-7fde-4b4b-8529-d9cc2a5cc2cb',
     tableId: 'PLCAB',
    4 serialNo: 'f1cef4cf-6692-4a47-994a-20da46f7b512',
    � command: <Buffer 7b 22 66 6f 72 6d 22 3a 5b 7b 22 61 72 72 61 79 56 61 6c 75 65 22 3a 6e 75 6c 6c 2c 22 69 66 52 65 70 65 61 74 22 3a 6e 75 6c 6c 2c 22 69 6f 77 61 79 ... 579 more bytes>
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -4.9,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:08:34.338Z,
     keepAlive: 0
    [ '192.168.1.130' ]
     设备192.168.1.130正在重连
    !设备192.168.1.1112正在重连
    &[ '192.168.1.130', '192.168.1.1112' ]
     设备192.168.1.515正在重连
    H[ '192.168.1.130', '192.168.1.1112', '192.168.1.515', '192.168.1.200' ]
    重试失败finally
    -重试失败finally,retryDevices删除client
    重试失败finally
    7[ '192.168.1.130', '192.168.1.1112', '192.168.1.200' ]
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:34.712000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:34.713000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:34.713000000+08:00"}
    重试失败finally
    &[ '192.168.1.1112', '192.168.1.200' ]
    [ '192.168.1.200' ]
    重试失败finally
    8健康检查返回值 { errors: [], status: 'SERVING' }
    健康检查正常
    �{"level":"ERROR","msg":"CCS读取异常:{} TIMEOUT occurred while writing Reading Tag Group.","stack":"Error: TIMEOUT occurred while writing Reading Tag Group.\n at Controller._readTagGroup (/app/abplc.js:66:8983)\n at TaskEasy._runTask (/app/abplc.js:90:18315)\n at TaskEasy._next (/app/abplc.js:90:18513)\n at /app/abplc.js:90:18437","time":"2024-01-18T10:08:35.731000000+08:00"}
    读取异常>3,删除client,{}
    a{"level":"ERROR","msg":"192.168.1.515发生 error","time":"2024-01-18T10:08:35.791000000+08:00"}
    7Caught exception: ReferenceError: error is not defined
    $Exception origin: uncaughtException
    ?Caught exception: Error: Socket Transmission Failure Occurred!
    b{"level":"ERROR","msg":"192.168.1.1112发生 error","time":"2024-01-18T10:08:35.826000000+08:00"}
    H{"level":"ERROR","msg":"一号破碎站数据读取异常:{} TIMEOUT occurred while writing Reading Tag Group.","stack":"Error: TIMEOUT occurred while writing Reading Tag Group.\n at Controller._readTagGroup (/app/abplc.js:66:8983)\n at TaskEasy._runTask (/app/abplc.js:90:18315)\n at TaskEasy._next (/app/abplc.js:90:18513)\n at /app/abplc.js:90:18437\n at runNextTicks (node:internal/process/task_queues:60:5)\n at listOnTimeout (node:internal/timers:538:9)\n at process.processTimers (node:internal/timers:512:7)","time":"2024-01-18T10:08:35.951000000+08:00"}
    读取异常>3,删除client,{}
    8{"level":"ERROR","msg":"PSZ_2读取异常:{} TIMEOUT occurred while writing Reading Tag Group.","stack":"Error: TIMEOUT occurred while writing Reading Tag Group.\n at Controller._readTagGroup (/app/abplc.js:66:8983)\n at TaskEasy._runTask (/app/abplc.js:90:18315)\n at TaskEasy._next (/app/abplc.js:90:18513)\n at /app/abplc.js:90:18437\n at runNextTicks (node:internal/process/task_queues:60:5)\n at listOnTimeout (node:internal/timers:538:9)\n at process.processTimers (node:internal/timers:512:7)","time":"2024-01-18T10:08:35.952000000+08:00"}
    读取异常>3,删除client,{}
    �{"level":"ERROR","msg":"PSZ_3读取异常:{} TIMEOUT occurred while writing Reading Tag Group.","stack":"Error: TIMEOUT occurred while writing Reading Tag Group.\n at Controller._readTagGroup (/app/abplc.js:66:8983)\n at TaskEasy._runTask (/app/abplc.js:90:18315)\n at TaskEasy._next (/app/abplc.js:90:18513)\n at /app/abplc.js:90:18437","time":"2024-01-18T10:08:35.955000000+08:00"}
    读取异常>3,删除client,{}
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:36.199000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:36.200000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:36.200000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:36.200000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:36.200000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:36.200000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:36.200000000+08:00"}
    run接收数据 {
    3 request: 'ae15bbd4-1ae0-40c7-a7a4-5bab014411e6',
     tableId: 'PLCAB',
    4 serialNo: '18a92a95-d2fc-45ed-9bde-ea0f6268eca0',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -14.8,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:08:36.207Z,
     keepAlive: 0
    run接收数据 {
    3 request: '52d8b7de-702e-4868-8d43-5c47d2897fe8',
     tableId: 'PLCAB',
    4 serialNo: '96369415-8365-467e-aa71-355bcd127435',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -16.3,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:08:36.295Z,
     keepAlive: 0
    run接收数据 {
    3 request: '148487a2-d2f0-49d4-8249-282894ae6bb8',
     tableId: 'PLCAB',
    4 serialNo: '2c03f2c7-c9a5-494c-a588-44cd8381d3ee',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -4.9,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:08:36.321Z,
     keepAlive: 0
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:36.699000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:36.699000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:36.700000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:36.700000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:36.700000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:36.700000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:36.700000000+08:00"}
    a{"level":"ERROR","msg":"192.168.1.200发生 error","time":"2024-01-18T10:08:36.809000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:37.199000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:37.199000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:37.200000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:37.200000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:37.200000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:37.200000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:37.200000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:37.699000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:37.700000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:37.700000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:37.700000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:37.700000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:37.700000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:37.701000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:38.199000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:38.200000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:38.200000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:38.200000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:38.200000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:38.200000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:38.201000000+08:00"}
    run接收数据 {
    3 request: '5b4c30d0-4383-4730-87a9-b5e518b01760',
     tableId: 'PLCAB',
    4 serialNo: 'dc45d05e-5a16-40c8-80f1-6ceedf1c9086',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -14.9,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:08:38.209Z,
     keepAlive: 0
    run接收数据 {
    3 request: 'f96b42ae-b5aa-4fbe-a1a1-127f4abc2fdf',
     tableId: 'PLCAB',
    4 serialNo: 'a1ff9ef0-804f-4b4d-bf3a-be2e89e864b2',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -16.3,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:08:38.387Z,
     keepAlive: 0
    run接收数据 {
    3 request: 'd64d1222-16b7-4443-bef1-28628860fefe',
     tableId: 'PLCAB',
    4 serialNo: 'a26c167d-8082-496d-afbc-03349271b476',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -4.9,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:08:38.405Z,
     keepAlive: 0
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:38.700000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:38.700000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:38.700000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:38.700000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:38.701000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:38.701000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:38.701000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:39.201000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:39.201000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:39.201000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:39.201000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:39.202000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:39.202000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:39.202000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:39.702000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:39.702000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:39.702000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:39.702000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:39.703000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:39.703000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:39.703000000+08:00"}
    健康检查正常
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:40.202000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:40.202000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:40.202000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:40.203000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:40.203000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:40.203000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:40.203000000+08:00"}
    run接收数据 {
    3 request: 'e3cf5ec0-2aaa-43f2-b48c-50f8119d0822',
     tableId: 'PLCAB',
    4 serialNo: 'a8ac1da6-21c0-4dc5-8476-508f565d0c94',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -14.8,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:08:40.222Z,
     keepAlive: 0
    run接收数据 {
    3 request: '5e6bd745-a058-4c3f-a79e-07bb459008cb',
     tableId: 'PLCAB',
    4 serialNo: 'f3c3e783-8292-4e63-8e69-15208ebde150',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -16.2,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:08:40.326Z,
     keepAlive: 0
    run接收数据 {
    3 request: '03ef4ef2-3790-4806-8c63-19f27b39d75e',
     tableId: 'PLCAB',
    4 serialNo: '65a5a8b8-579a-4f59-a3ed-bd7a601af2b2',
    � command: <Buffer 7b 22 66 6f 72 6d 22 3a 5b 7b 22 61 72 72 61 79 56 61 6c 75 65 22 3a 6e 75 6c 6c 2c 22 69 66 52 65 70 65 61 74 22 3a 6e 75 6c 6c 2c 22 69 6f 77 61 79 ... 577 more bytes>
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -5,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:08:40.338Z,
     keepAlive: 0
    i{"level":"ERROR","msg":"PSZ_1无对应连接192.168.1.130","time":"2024-01-18T10:08:40.702000000+08:00"}
    y{"level":"ERROR","msg":"一号破碎站数据无对应连接192.168.1.130","time":"2024-01-18T10:08:40.703000000+08:00"}
    z{"level":"ERROR","msg":"二号破碎站数据无对应连接192.168.1.1112","time":"2024-01-18T10:08:40.703000000+08:00"}
    j{"level":"ERROR","msg":"PSZ_2无对应连接192.168.1.1112","time":"2024-01-18T10:08:40.703000000+08:00"}
    y{"level":"ERROR","msg":"三号破碎站数据无对应连接192.168.1.515","time":"2024-01-18T10:08:40.703000000+08:00"}
    g{"level":"ERROR","msg":"CCS无对应连接192.168.1.200","time":"2024-01-18T10:08:40.703000000+08:00"}
    i{"level":"ERROR","msg":"PSZ_3无对应连接192.168.1.515","time":"2024-01-18T10:08:40.703000000+08:00"}
  • guangdaG 离线
    guangdaG 离线
    guangda
    驱动管理页面 在设备监控功能下面
  • Y 在线
    Y 在线
    yfyfzw
    这个是刚刚发生的突然都连不上了,是软件不稳定吗
  • Y 在线
    Y 在线
    yfyfzw
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -5,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:11:42.340Z,
     keepAlive: 0
    @{"level":"ERROR","msg":"CCS Micro Queue is already full at size of 100!!!","stack":"Error: Micro Queue is already full at size of 100!!!\n at TaskEasy.schedule (/app/abplc.js:90:17492)\n at Controller.readTagGroup (/app/abplc.js:66:7234)\n at AbDriver.readDevice (/app/abplc.js:1:789766)\n at /app/abplc.js:1:789274\n at Array.forEach (<anonymous>)\n at AbDriver.readDevices (/app/abplc.js:1:789052)\n at listOnTimeout (node:internal/timers:569:17)\n at process.processTimers (node:internal/timers:512:7)","time":"2024-01-18T10:11:43.818000000+08:00"}
    run接收数据 {
    3 request: '9b4a4ee7-decc-4bc4-bb38-ea4372661911',
     tableId: 'PLCAB',
    4 serialNo: '3517465b-5a95-4bb2-8402-1da69f837165',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -14.8,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:11:44.189Z,
     keepAlive: 0
    run接收数据 {
    3 request: 'c8d5a811-559e-4511-8ded-9d10f357083e',
     tableId: 'PLCAB',
    4 serialNo: 'de71a765-e838-4b8d-934a-f18f8252c8c3',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -16.5,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:11:44.296Z,
     keepAlive: 0
    run接收数据 {
    3 request: 'b4fd2f5a-79f2-42a3-95d1-d0eee158869d',
     tableId: 'PLCAB',
    4 serialNo: 'a6fb90ea-c49b-4f40-a593-edb0bb2ffe90',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -5.1,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:11:44.325Z,
     keepAlive: 0
    健康检查正常
    @{"level":"ERROR","msg":"CCS Micro Queue is already full at size of 100!!!","stack":"Error: Micro Queue is already full at size of 100!!!\n at TaskEasy.schedule (/app/abplc.js:90:17492)\n at Controller.readTagGroup (/app/abplc.js:66:7234)\n at AbDriver.readDevice (/app/abplc.js:1:789766)\n at /app/abplc.js:1:789274\n at Array.forEach (<anonymous>)\n at AbDriver.readDevices (/app/abplc.js:1:789052)\n at listOnTimeout (node:internal/timers:569:17)\n at process.processTimers (node:internal/timers:512:7)","time":"2024-01-18T10:11:45.328000000+08:00"}
    run接收数据 {
    3 request: '375c8702-663b-4bec-b9c3-06ad5f6a5789',
     tableId: 'PLCAB',
    4 serialNo: '734918ef-3b0d-42ae-9dca-01d61b283df2',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -14.8,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:11:46.203Z,
     keepAlive: 0
    run接收数据 {
    3 request: 'f3f28783-7dfd-44f5-a29e-d5bc9723e4b9',
     tableId: 'PLCAB',
    4 serialNo: '892c67c9-7dc4-45f7-93a1-e4a7f6e13bbe',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -16.5,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:11:46.266Z,
     keepAlive: 0
    @{"level":"ERROR","msg":"CCS Micro Queue is already full at size of 100!!!","stack":"Error: Micro Queue is already full at size of 100!!!\n at TaskEasy.schedule (/app/abplc.js:90:17492)\n at Controller.readTagGroup (/app/abplc.js:66:7234)\n at AbDriver.readDevice (/app/abplc.js:1:789766)\n at /app/abplc.js:1:789274\n at Array.forEach (<anonymous>)\n at AbDriver.readDevices (/app/abplc.js:1:789052)\n at listOnTimeout (node:internal/timers:569:17)\n at process.processTimers (node:internal/timers:512:7)","time":"2024-01-18T10:11:46.323000000+08:00"}
    run接收数据 {
    3 request: 'a9bf3713-76b7-43e1-850d-72ea1cc7cb74',
     tableId: 'PLCAB',
    4 serialNo: 'f31c1b92-e492-4482-9480-8f57286464ec',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -5,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:11:46.328Z,
     keepAlive: 0
    @{"level":"ERROR","msg":"CCS Micro Queue is already full at size of 100!!!","stack":"Error: Micro Queue is already full at size of 100!!!\n at TaskEasy.schedule (/app/abplc.js:90:17492)\n at Controller.readTagGroup (/app/abplc.js:66:7234)\n at AbDriver.readDevice (/app/abplc.js:1:789766)\n at /app/abplc.js:1:789274\n at Array.forEach (<anonymous>)\n at AbDriver.readDevices (/app/abplc.js:1:789052)\n at listOnTimeout (node:internal/timers:569:17)\n at process.processTimers (node:internal/timers:512:7)","time":"2024-01-18T10:11:47.823000000+08:00"}
    run接收数据 {
    3 request: '1b273f8e-10ca-495f-82ab-001f16f15d4e',
     tableId: 'PLCAB',
    4 serialNo: 'f307f28e-ea49-479a-8bbc-4426a17017ad',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -14.6,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:11:48.191Z,
     keepAlive: 0
    run接收数据 {
    3 request: '033d93c7-e902-458e-a747-a3687d69aead',
     tableId: 'PLCAB',
    4 serialNo: '963d5993-6003-4ba4-b091-17429ec2c5ff',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -16.5,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:11:48.331Z,
     keepAlive: 0
    run接收数据 {
    3 request: 'b977de4c-bc2f-406b-b9a1-dbd9dab4c660',
     tableId: 'PLCAB',
    4 serialNo: '6ae33ca3-8415-414f-9dbe-c0d7e18cc535',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -5,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:11:48.340Z,
     keepAlive: 0
    @{"level":"ERROR","msg":"CCS Micro Queue is already full at size of 100!!!","stack":"Error: Micro Queue is already full at size of 100!!!\n at TaskEasy.schedule (/app/abplc.js:90:17492)\n at Controller.readTagGroup (/app/abplc.js:66:7234)\n at AbDriver.readDevice (/app/abplc.js:1:789766)\n at /app/abplc.js:1:789274\n at Array.forEach (<anonymous>)\n at AbDriver.readDevices (/app/abplc.js:1:789052)\n at listOnTimeout (node:internal/timers:569:17)\n at process.processTimers (node:internal/timers:512:7)","time":"2024-01-18T10:11:48.823000000+08:00"}
    @{"level":"ERROR","msg":"CCS Micro Queue is already full at size of 100!!!","stack":"Error: Micro Queue is already full at size of 100!!!\n at TaskEasy.schedule (/app/abplc.js:90:17492)\n at Controller.readTagGroup (/app/abplc.js:66:7234)\n at AbDriver.readDevice (/app/abplc.js:1:789766)\n at /app/abplc.js:1:789274\n at Array.forEach (<anonymous>)\n at AbDriver.readDevices (/app/abplc.js:1:789052)\n at listOnTimeout (node:internal/timers:569:17)\n at process.processTimers (node:internal/timers:512:7)","time":"2024-01-18T10:11:49.828000000+08:00"}
    健康检查正常
    run接收数据 {
    3 request: '93f875eb-7dfd-4bc7-a636-b0d187fab1ad',
     tableId: 'PLCAB',
    4 serialNo: '15215185-e432-4ffe-9156-7107d848f32c',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -14.7,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:11:50.192Z,
     keepAlive: 0
    run接收数据 {
    3 request: 'd746eadb-2d8c-40de-aec7-33afe49aa894',
     tableId: 'PLCAB',
    4 serialNo: '50fbb809-7458-4e22-9386-e54f77a2253c',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -16.5,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:11:50.279Z,
     keepAlive: 0
    run接收数据 {
    3 request: '3c038924-4e32-45a7-89d4-74b1329268fa',
     tableId: 'PLCAB',
    4 serialNo: 'e106c22c-bb01-4c8d-a493-5c8db0f5fec9',
     ab run..
     Tag0 Tag {
     _eventsCount: 0,
     state: {
     tag: {
     type: 202,
     bitIndex: null,
     value: -5,
     program: null,
     stage_write: true
     read_size: 1,
    ) timestamp: 2024-01-18T02:11:50.329Z,
     keepAlive: 0
  • Y 在线
    Y 在线
    yfyfzw
    现场是linux服务器,AB PLC,服务都是更新到最新的,麻烦检查下日志是否有问题
  • guangdaG 离线
    guangdaG 离线
    guangda
    设备那边网络有问题吗
  • Y 在线
    Y 在线
    yfyfzw
    没有,就算有也不可能四个不同方向的PLC都掉线
    这个错误是什么?
    guangdaG 1 条回复 最后回复
  • guangdaG 离线
    guangdaG 离线
    guangda
    在 中回复了 yfyfzw 最后由 编辑
    #39
    @yfyfzw 已远程查看
    徐YC徐 1 条回复 最后回复
  • 徐YC徐 离线
    徐YC徐 离线
    徐YC
    在 中回复了 guangda 最后由 编辑
    #40
    guangdaG 1 条回复 最后回复
  • guangdaG 离线
    guangdaG 离线
    guangda
    在 中回复了 徐YC 最后由 编辑
    #41
    @徐YC 哪里有问题可以 再设备接入这个主题下面添加新的文章 提问
