  3. SL651遥测站定时报上报数据,平台不显示
    看一下数据点有没有历史数据
    hk
    有历史数据,但时间存在问题
    看一下驱动实例里面的配置,这个位置
    hk
    重新导出一份驱动日志,我们这边开发看一下
    hk
    �2025-04-10T02:45:46.585572829Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.585000000Z","projectId":"hyznsl","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"报文处理器","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.server.handlers.HexBCDDatagramFrameDecoder:61"},"msg":"数据帧[hex]: M3: false, 正文长度: 40"}
    �2025-04-10T02:45:46.585599921Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.585000000Z","projectId":"hyznsl","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"报文处理器","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.server.handlers.HexBCDDatagramFrameDecoder:69"},"msg":"数据帧[hex]: M3: false, 有效正文长度: 40"}
    �2025-04-10T02:45:46.585689569Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.585000000Z","projectId":"hyznsl","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"报文处理器","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.server.handlers.HexBCDDatagramFrameDecoder:93"},"msg":"数据帧CRC[hex]: expected: [30, -25], got: [30, -25]"}
    �2025-04-10T02:45:46.585791550Z {"logType":"syslog","level":"INFO","time":"2025-04-10T02:45:46.585000000Z","projectId":"hyznsl","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"报文处理器","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.server.handlers.HexBCDDatagramFrameDecoder:107"},"msg":"累积接收到数据帧[hex]: 2 个"}
    f2025-04-10T02:45:46.585968072Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.585000000Z","projectId":"hyznsl","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"报文处理器","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.server.handlers.DatagramPrettyHandler:30"},"msg":"接收报文:
    62025-04-10T02:45:46.585992538Z 帧起始符: 7e7e
    62025-04-10T02:45:46.585999050Z 中心站地址: 0A
    >2025-04-10T02:45:46.586004038Z 遥测站地址: 1122334455
    02025-04-10T02:45:46.586009259Z 密码: 9988
    12025-04-10T02:45:46.586029316Z 功能码: 32
    <2025-04-10T02:45:46.586034737Z 上下行标识: UPSTREAM
    42025-04-10T02:45:46.586039896Z 正文长度: 40
    72025-04-10T02:45:46.586045196Z 报文起始符: STX
    �2025-04-10T02:45:46.586050597Z 报文正文: [0, 2, 37, 4, 16, 16, 69, 69, -15, -15, 17, 34, 51, 68, 85, 72, -16, -16, 37, 4, 16, 16, 69, 24, 17, 5, 24, 2, 17, 2, 82, 8, 24, 0, 16, 8, 56, 18, 17, -108]
    72025-04-10T02:45:46.586056447Z 报文结束符: ETX
    :2025-04-10T02:45:46.586061207Z CRC: [30, -25]. Passed
    #2025-04-10T02:45:46.586066266Z "}
    �2025-04-10T02:45:46.586151066Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.585000000Z","projectId":"hyznsl","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"报文处理器","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.protocols.standard.CommonChannelHandler:46"},"msg":"Common-Decode(32): cn.airiot.sl651.protocol.datagram.BaseDatagram@150a540d"}
    �2025-04-10T02:45:46.586488899Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.586000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"启动驱动","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.protocols.standard.StandardChannelHandler:96","raw":{"FnCode":"32","TelegramAddress":"1122334455"}"},"msg":"Common-Decode(32): 编码要素, H18, 湿度"}
    �2025-04-10T02:45:46.586721968Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.586000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"启动驱动","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.protocols.standard.StandardChannelHandler:177","raw":{"FnCode":"32","TelegramAddress":"1122334455"}"},"msg":"Common-Decode(32): 编码要素: 湿度(H18), 51.8"}
    �2025-04-10T02:45:46.586944405Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.586000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"启动驱动","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.protocols.standard.StandardChannelHandler:96","raw":{"FnCode":"32","TelegramAddress":"1122334455"}"},"msg":"Common-Decode(32): 编码要素, H02, 瞬时气温"}
    �2025-04-10T02:45:46.587059381Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.586000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"启动驱动","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.protocols.standard.StandardChannelHandler:177","raw":{"FnCode":"32","TelegramAddress":"1122334455"}"},"msg":"Common-Decode(32): 编码要素: 瞬时气温(H02), 25.2"}
    �2025-04-10T02:45:46.587194676Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.587000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"启动驱动","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.protocols.standard.StandardChannelHandler:96","raw":{"FnCode":"32","TelegramAddress":"1122334455"}"},"msg":"Common-Decode(32): 编码要素, H08, 气压"}
    �2025-04-10T02:45:46.587313870Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.587000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"启动驱动","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.protocols.standard.StandardChannelHandler:177","raw":{"FnCode":"32","TelegramAddress":"1122334455"}"},"msg":"Common-Decode(32): 编码要素: 气压(H08), 1008"}
    �2025-04-10T02:45:46.587508936Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.587000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"启动驱动","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.protocols.standard.StandardChannelHandler:96","raw":{"FnCode":"32","TelegramAddress":"1122334455"}"},"msg":"Common-Decode(32): 编码要素, H38, 电源电压"}
    �2025-04-10T02:45:46.587639340Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.587000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"启动驱动","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.protocols.standard.StandardChannelHandler:177","raw":{"FnCode":"32","TelegramAddress":"1122334455"}"},"msg":"Common-Decode(32): 编码要素: 电源电压(H38), 11.94"}
    2025-04-10T02:45:46.587851510Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.587000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"启动驱动","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.protocols.standard.StandardChannelHandler:101","raw":{"FnCode":"32","TelegramAddress":"1122334455"}"},"msg":"Common-Decode(32): [PointField{identifier='H18', serialNumber=null, time=1744253145000, value=51.8}, PointField{identifier='H02', serialNumber=null, time=1744253145000, value=25.2}, PointField{identifier='H08', serialNumber=null, time=1744253145000, value=1008}, PointField{identifier='H38', serialNumber=null, time=1744253145000, value=11.94}]"}
    �2025-04-10T02:45:46.588014185Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.587000000Z","projectId":"hyznsl","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"报文处理器","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.protocols.standard.CommonChannelHandler:59"},"msg":"Common-Decode(32): [PointField{identifier='H18', serialNumber=null, time=1744253145000, value=51.8}, PointField{identifier='H02', serialNumber=null, time=1744253145000, value=25.2}, PointField{identifier='H08', serialNumber=null, time=1744253145000, value=1008}, PointField{identifier='H38', serialNumber=null, time=1744253145000, value=11.94}]"}
    2025-04-10T02:45:46.588249397Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.587000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.core.SL651DataSender:232"},"msg":"发送数据: 遥测站: 1122334455, 时间: 1744253145000, 功能码: 32, 采集数据: [PointField{identifier='H18', serialNumber=null, time=1744253145000, value=51.8}, PointField{identifier='H02', serialNumber=null, time=1744253145000, value=25.2}, PointField{identifier='H08', serialNumber=null, time=1744253145000, value=1008}, PointField{identifier='H38', serialNumber=null, time=1744253145000, value=11.94}]"}
    �2025-04-10T02:45:46.588271779Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.588000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.core.SL651DataSender:240"},"msg":"发送数据: 遥测站: 1122334455, 关联资产, 表=演示水雨情,设备=演示水雨情"}
    �2025-04-10T02:45:46.588443872Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.588000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.core.SL651DataSender:148"},"msg":"获取数据点: 表=演示水雨情,设备=11223344. 未在设备下找到标识符对应的数据点, 功能码: 32 标识符: SendTime"}
    b2025-04-10T02:45:46.588483787Z {"logType":"syslog","level":"WARN","time":"2025-04-10T02:45:46.588000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.core.SL651DataSender:261"},"msg":"发送数据: 未找到匹配的数据点, 遥测站: 1122334455, 功能码: 32 采集数据: [PointField{identifier='H18', serialNumber=null, time=1744253145000, value=51.8}, PointField{identifier='H02', serialNumber=null, time=1744253145000, value=25.2}, PointField{identifier='H08', serialNumber=null, time=1744253145000, value=1008}, PointField{identifier='H38', serialNumber=null, time=1744253145000, value=11.94}, PointField{identifier='SendTime', serialNumber=null, time=0, value=2025-04-10 10:45:45}]"}
    92025-04-10T02:45:46.588634199Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.588000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.core.SL651DataSender:171"},"msg":"获取数据点: 表=演示水雨情,设备=11223344. 找到数据点, 功能码: 32 标识符: H18, 数据点: [Field{tag=Tag{id='sd', name='湿度', tagValue=null, range=null, fixed=1, mod=null}, value=51.8}]"}
    92025-04-10T02:45:46.588744537Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.588000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.core.SL651DataSender:171"},"msg":"获取数据点: 表=演示水雨情,设备=11223344. 找到数据点, 功能码: 32 标识符: H02, 数据点: [Field{tag=Tag{id='wd', name='温度', tagValue=null, range=null, fixed=1, mod=null}, value=25.2}]"}
    82025-04-10T02:45:46.589004846Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.588000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.core.SL651DataSender:171"},"msg":"获取数据点: 表=演示水雨情,设备=11223344. 找到数据点, 功能码: 32 标识符: H08, 数据点: [Field{tag=Tag{id='qy', name='气压', tagValue=null, range=null, fixed=1, mod=1.0}, value=1008}]"}
    �2025-04-10T02:45:46.589025884Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.588000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.core.SL651DataSender:148"},"msg":"获取数据点: 表=演示水雨情,设备=11223344. 未在设备下找到标识符对应的数据点, 功能码: 32 标识符: H38"}
    �2025-04-10T02:45:46.589152794Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.588000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.core.SL651DataSender:268"},"msg":"发送数据: Point{id='11223344', cid='null', table='演示水雨情', time=1744253145000, fields=[Field{tag=Tag{id='sd', name='湿度', tagValue=null, range=null, fixed=1, mod=null}, value=51.8}, Field{tag=Tag{id='wd', name='温度', tagValue=null, range=null, fixed=1, mod=null}, value=25.2}, Field{tag=Tag{id='qy', name='气压', tagValue=null, range=null, fixed=1, mod=1.0}, value=1008}], fieldTypes={}}"}
    2025-04-10T02:45:46.589287987Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.589000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"视频水雨情监测站","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.AbstractDataSender:347"},"msg":"上报数据: Point{id='11223344', cid='null', table='演示水雨情', time=1744253145000, fields=[Field{tag=Tag{id='sd', name='湿度', tagValue=null, range=null, fixed=1, mod=null}, value=51.8}, Field{tag=Tag{id='wd', name='温度', tagValue=null, range=null, fixed=1, mod=null}, value=25.2}, Field{tag=Tag{id='qy', name='气压', tagValue=null, range=null, fixed=1, mod=1.0}, value=1008}], fieldTypes={}}"}
    �2025-04-10T02:45:46.589484908Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.589000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.driver.service.BaseValueDataHandler:46"},"msg":"数据点[基值]处理器: 设备表=演示水雨情,设备=11223344,数据点=sd. 数据点未设置基值"}
    2025-04-10T02:45:46.589532758Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.589000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.ConvertValueHandler:96"},"msg":"数据点[数值转换]处理器: 设备表=演示水雨情,设备=11223344,数据点=sd. 映射配置 null, 数据点的值 51.8, 条件是否满足 false"}
    2025-04-10T02:45:46.589699350Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.589000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.RoundAndScaleValueHandler:99"},"msg":"数数据点[小数位数和缩放比例]处理器: 设备表=演示水雨情,设备=11223344,数据点=sd. 数据点的值为 51.8, 最终值为 51.8"}
    2025-04-10T02:45:46.589807574Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.589000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.RangeValueHandler:86"},"msg":"数据点[旧版有效范围]处理器: 设备表=演示水雨情,设备=11223344,数据点=sd. 有效范围配置 null, 数据点的值 51.8, 条件是否满足 false"}
    �2025-04-10T02:45:46.589988573Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.589000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.RangeValueHandlerV2:62"},"msg":"数据点[有效范围]处理器: 设备表=演示水雨情,设备=11223344,数据点=sd. tag 或 value 为 null, 不支持处理"}
    <2025-04-10T02:45:46.590020223Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.589000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.InvalidRangeValueHandler:54"},"msg":"数据点[无效范围]处理器: 设备表=演示水雨情,设备=11223344,数据点=sd. 无效范围配置无效或者数据点的值不是数值, 不处理, 配置 null, 数据点的值 51.8"}
    �2025-04-10T02:45:46.590143464Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.590000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.driver.service.BaseValueDataHandler:46"},"msg":"数据点[基值]处理器: 设备表=演示水雨情,设备=11223344,数据点=wd. 数据点未设置基值"}
    2025-04-10T02:45:46.590339202Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.590000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.ConvertValueHandler:96"},"msg":"数据点[数值转换]处理器: 设备表=演示水雨情,设备=11223344,数据点=wd. 映射配置 null, 数据点的值 25.2, 条件是否满足 false"}
    2025-04-10T02:45:46.590359830Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.590000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.RoundAndScaleValueHandler:99"},"msg":"数数据点[小数位数和缩放比例]处理器: 设备表=演示水雨情,设备=11223344,数据点=wd. 数据点的值为 25.2, 最终值为 25.2"}
    2025-04-10T02:45:46.590473735Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.590000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.RangeValueHandler:86"},"msg":"数据点[旧版有效范围]处理器: 设备表=演示水雨情,设备=11223344,数据点=wd. 有效范围配置 null, 数据点的值 25.2, 条件是否满足 false"}
    �2025-04-10T02:45:46.590668229Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.590000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.RangeValueHandlerV2:62"},"msg":"数据点[有效范围]处理器: 设备表=演示水雨情,设备=11223344,数据点=wd. tag 或 value 为 null, 不支持处理"}
    <2025-04-10T02:45:46.590689671Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.590000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.InvalidRangeValueHandler:54"},"msg":"数据点[无效范围]处理器: 设备表=演示水雨情,设备=11223344,数据点=wd. 无效范围配置无效或者数据点的值不是数值, 不处理, 配置 null, 数据点的值 25.2"}
    �2025-04-10T02:45:46.590791953Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.590000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.driver.service.BaseValueDataHandler:46"},"msg":"数据点[基值]处理器: 设备表=演示水雨情,设备=11223344,数据点=qy. 数据点未设置基值"}
    2025-04-10T02:45:46.590903863Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.590000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.ConvertValueHandler:96"},"msg":"数据点[数值转换]处理器: 设备表=演示水雨情,设备=11223344,数据点=qy. 映射配置 null, 数据点的值 1008, 条件是否满足 false"}
    2025-04-10T02:45:46.591042784Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.590000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.RoundAndScaleValueHandler:99"},"msg":"数数据点[小数位数和缩放比例]处理器: 设备表=演示水雨情,设备=11223344,数据点=qy. 数据点的值为 1008, 最终值为 1008.0"}
    2025-04-10T02:45:46.591191764Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.591000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.RangeValueHandler:86"},"msg":"数据点[旧版有效范围]处理器: 设备表=演示水雨情,设备=11223344,数据点=qy. 有效范围配置 null, 数据点的值 1008.0, 条件是否满足 false"}
    �2025-04-10T02:45:46.591276123Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.591000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.RangeValueHandlerV2:62"},"msg":"数据点[有效范围]处理器: 设备表=演示水雨情,设备=11223344,数据点=qy. tag 或 value 为 null, 不支持处理"}
    >2025-04-10T02:45:46.591376701Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.591000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.handlers.InvalidRangeValueHandler:54"},"msg":"数据点[无效范围]处理器: 设备表=演示水雨情,设备=11223344,数据点=qy. 无效范围配置无效或者数据点的值不是数值, 不处理, 配置 null, 数据点的值 1008.0"}
    �2025-04-10T02:45:46.591594370Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.591000000Z","projectId":"","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"写数据点值","table":"演示水雨情","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.AbstractDataSender:378"},"msg":"采集数据处理: 原始数据: Point{id='11223344', cid='null', table='演示水雨情', time=1744253145000, fields=[Field{tag=Tag{id='sd', name='湿度', tagValue=null, range=null, fixed=1, mod=null}, value=51.8}, Field{tag=Tag{id='wd', name='温度', tagValue=null, range=null, fixed=1, mod=null}, value=25.2}, Field{tag=Tag{id='qy', name='气压', tagValue=null, range=null, fixed=1, mod=1.0}, value=1008}], fieldTypes={}}, 处理后数据: Point{id='11223344', cid='null', table='演示水雨情', time=1744253145000, fields=[Field{tag=Tag{id='sd', name='湿度', tagValue=null, range=null, fixed=1, mod=null}, value=51.8}, Field{tag=Tag{id='wd', name='温度', tagValue=null, range=null, fixed=1, mod=null}, value=25.2}, Field{tag=Tag{id='qy', name='气压', tagValue=null, range=null, fixed=1, mod=1.0}, value=1008.0}], fieldTypes={}}"}
    �2025-04-10T02:45:46.592305706Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.592000000Z","projectId":"hyznsl","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"启动驱动","group":"666d3f439127f5b206f91fb6","data":{"line":"io.github.airiot.sdk.driver.data.impl.MQTTDataSender:255"},"msg":"MQTTDataSender: 数据已发送, MessageId[0], Qos[0], Payload[{"fields":{"sd":51.8,"wd":25.2,"qy":1008.0},"source":"device","time":1744253145000}]"}
    f2025-04-10T02:45:46.592946599Z {"logType":"syslog","level":"DEBUG","time":"2025-04-10T02:45:46.592000000Z","projectId":"hyznsl","service":"hyznsl-666d3f439127f5b206f91fb6-sl651-2014-driver","module":"报文处理器","group":"666d3f439127f5b206f91fb6","data":{"line":"cn.airiot.sl651.server.handlers.DatagramPrettyHandler:23"},"msg":"发送报文:
    62025-04-10T02:45:46.592964974Z 帧起始符: 7e7e
    62025-04-10T02:45:46.592971146Z 中心站地址: 0A
    >2025-04-10T02:45:46.592976155Z 遥测站地址: 1122334455
    02025-04-10T02:45:46.592980994Z 密码: 9988
    12025-04-10T02:45:46.592986024Z 功能码: 32
    >2025-04-10T02:45:46.592990623Z 上下行标识: DOWNSTREAM
    32025-04-10T02:45:46.592995170Z 正文长度: 8
    72025-04-10T02:45:46.592999059Z 报文起始符: STX
    O2025-04-10T02:45:46.593003827Z 报文正文: [0, 2, 37, 4, 16, 16, 69, 70]
    72025-04-10T02:45:46.593008386Z 报文结束符: ACK
    ;2025-04-10T02:45:46.593012072Z CRC: [118, 123]. Passed
    #2025-04-10T02:45:46.593015890Z "}
    hk
    目前就这个数值显示异常
    我看你发的日志中发送的数据的时间是对的,这个日志的打印时间有时区,看着没问题,点一下查看历史数据,用表格显示看看时间,确认一下历史数据的时间对不对,我看驱动发送的数据没问题
    hk
    历史数据表格显示有数值,但实时数据显示错误
    这个是之前上报过 2070年的数据,后面上报的数据都比这个时间早,所以实时数据不刷新了。这个得去清缓存,或者把数据点标识改一下
