  3. docker重启后模块一直在重启状态,可以打开运维平台,日志显示Redis客户端Ping错误: dial tcp: lookup redis on 127.0.0.11:53: read udp 127.0.0.1:57283->127.0.0.11:53: read: connection refused
    依次执行以下命令试一下: ./runOperation.sh
    ./run.sh
    W 1 条回复 最后回复
  • W 离线
    W 离线
    wyh
    @Zhang书书 在 docker重启后模块一直在重启状态,可以打开运维平台,日志显示Redis客户端Ping错误: dial tcp: lookup redis on 127.0.0.11:53: read udp 127.0.0.1:57283->127.0.0.11:53: read: connection refused 中说:
    ./run.sh
    运行了,但是好像并没有什么作用
    执行之后有什么报错吗?看一下core服务的日志报什么错
    W 1 条回复 最后回复
  • W 离线
    W 离线
    wyh
  • W 离线
    W 离线
    wyh
    �time="2025-03-04T16:36:52+08:00" level=error msg="Redis客户端Ping错误: dial tcp: lookup redis on 127.0.0.11:53: read udp 127.0.0.1:44030->127.0.0.11:53: read: connection refused" tag=main version=v3.7.116
  • W 离线
    W 离线
    wyh
     "UserName": "admin"
     "CORS": {
     "Enable": true,
     "AllowOrigins": [
     "AllowMethods": [
    "GET",
     "POST",
    "PUT",
    "DELETE",
     "PATCH"
     "AllowHeaders": [
     "Authorization",
    "Origin",
     "X-Requested-With",
     "Content-Type",
    "Accept",
     "X-Fingerprint",
     "x-access-path"
     "AllowCredentials": true,
     "MaxAge": 7200
     "GZIP": {
     "Enable": false,
     "ExcludedExtentions": [
     ".png",
     ".gif",
     ".jpeg",
    ".jpg"
     "ExcludedPaths": []
     "RateLimiter": {
     "Enable": false,
     "Count": 300,
     "RedisDB": 10
     "MQ": {
     "MQType": "mqtt",
     "TopicPrefix": "data/"
     "MQTT": {
     "Host": "mqtt",
     "Port": 1883,
     "Username": "admin",
     "Password": "public"
     "RabbitMQ": {
     "Host": "",
    "Port": 0,
     "Username": "",
     "Password": "",
     "VHost": "",
     "Exchange": "",
     "Queue": ""
     "JWTAuth": {
     "Enable": true,
     "SigningMethod": "HS512",
    " "SigningKey": "airiot20210427",
     "Expired": 259200,
     "Store": "file",
    " "FilePath": "data/jwt_auth.db",
     "RedisDB": 10,
     "RedisPrefix": "auth_"
    "API": {
     "Schema": "http",
     "Host": "",
     "Timeout": 60
     "Zeebe": {
    # "GatewayAddress": "zeebe:26500",
    ! "UsePlaintextConnection": true
     "Minio": {
     "Endpoint": "",
     "AccessKeyID": "",
     "SecretAccessKey": "",
     "UseSSl": false,
     "ExpireIn": 0
     "SpeechSynthesis": {
    " "Host": "speech_synthesis:8888"
     "Flow": {
     "Host": "flow-engine",
     "Port": 2333
    � "Warningkind": "[{"alert": true, \t"fix": true, \t"handle": true, \t"id": "ada21497-888f-4f6d-acc3-cb04250d8037", \t"name": "超限报警", \t"show": true }, { \t"alert": true, \t"fix": true, \t"handle": true, \t"id": "61024533-e716-439d-bf3f-e8f2a5c99128", \t"name": "仪表故障", \t"show": true }, { \t"alert": true, \t"fix": true, \t"handle": true, \t"id": "1f849be4-2907-4459-9665-3fda916bf286", \t"name": "其他报警", \t"show": true }, { \t"alert": true, \t"fix": true, \t"handle": true, \t"id": "1d345be4-2567-4764-7890-3ghj278vb342", \t"name": "数值超限", \t"show": true }, { \t"alert": true, \t"fix": true, \t"handle": true, \t"id": "1z875be4-2267-4564-7790-4kij278vb342", \t"name": "驱动掉线报警", \t"show": true }, { \t"alert": true, \t"fix": true, \t"handle": true, \t"id": "1z875xn8-2237-4544-7770-4kix918vb342", \t"name": "工作表数据报警", \t"show": true }, { \t"alert": true, \t"handle": true, \t"id": "1z875zt8-2357-4664-7756-4kfg9vzyu672", \t"name": "采集数据类型不一致", \t"show": true, \t"fix": true }]",
     "Operation": {
    ' "Address": "http://operation:10088",
     "Timeout": 60
    远程发一下我看看吧
    W 1 条回复 最后回复
  • W 离线
    W 离线
    wyh
    远程发一下我看看吧
    已发
    服务器中病毒了,建议先把服务器的病毒处理一下,再启动项目
  • W 离线
    W 离线
    wyh
    @Yoki 你好,昨天处理之后暂时没法解决服务器问题,决定在另外一台服务器上先部署平台,昨天备份了文件应该如何使用
    W 1 条回复 最后回复
  • W 离线
    W 离线
    wyh
    在 中回复了 wyh 最后由 编辑
    @wyh 在 docker重启后模块一直在重启状态,可以打开运维平台,日志显示Redis客户端Ping错误: dial tcp: lookup redis on 127.0.0.11:53: read udp 127.0.0.1:57283->127.0.0.11:53: read: connection refused 中说:
    airiot.tar.gz这个压缩文件
  • W 离线
    W 离线
    wyh
  • W wyh 在 中 引用了 这个主题
